use something like this:
#include <libraries/Oscillator/Oscillator.h>
#include <MiscUtilities.h>
Oscillator gOsc;
Scope gScope;
printf("Running with %d audio inputs and %d audio outputs\n", context->audioInChannels, context->audioOutChannels);
gOsc.setup(context->audioSampleRate);
gScope.setup(context->audioInChannels, context->audioSampleRate);
PinmuxUtils::set("P8_33", "mcasp");
float out = gOsc.process(440);
for(unsigned int c = 0; c < context->audioOutChannels; ++c)
// scope all audio inputs at once
gScope.log(context->audioIn + n * context->audioInChannels);
if it doesn't show "4 audio inputs and 4 audio outputs", then check you set the command line options appropriately.
This is also writing a sinewave to the output, to ensure it's still working.
