groumpf I have manage to get enviroment setup fine. Thank you very much for the your time and effort. The only issue I'm having is with the debugger. While debugging, if I step into a Bela function such as scope.setup() I get
Program terminated with signal
SIGSEGV, Segmentation fault.
The program no longer exists.
And I cant seem to to get it to use the local sysroot, meaning it loads the symbols from the BBB target.
7-interpreter-exec console "set sysroot /usr/local/linaro/BelaSysroot/"
Reading symbols from /home/e/bela_labs/xc-bela-cmake/build/bin/gdb_test...
Warning: 'set target-async', an alias for the command 'set mi-async', is deprecated.
Use 'set mi-async'.
Reading /lib/ld-linux-armhf.so.3 from remote target...
warning: File transfers from remote targets can be slow. Use "set sysroot" to access files locally instead.
Have had this issue? any idea on how to resolve it?
