try running in the console at the bottom of the IDE journalctl -u bela_startup -n 20000| cat and paste the full output of that command here.
  • luis replied to this.
    giuliomoro Here it is:
    root@bela ~/Bela# journalctl -u bela_startup -n 20000| cat
    -- Logs begin at Thu 2016-11-03 17:16:43 UTC, end at Sat 2022-11-05 10:17:24 UTC. --
    Nov 03 17:16:51 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:16:51 bela stdbuf[241]: make: Entering directory '/root/Bela'
    Nov 03 17:16:53 bela stdbuf[241]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287783 s in the future
    Nov 03 17:16:53 bela stdbuf[241]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:16:55 bela stdbuf[241]: backtrace() returned 0 addresses
    Nov 03 17:16:55 bela stdbuf[241]: Csound tidy up: Segmentation fault
    Nov 03 17:16:55 bela stdbuf[241]: bash: line 1:   414 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:16:55 bela stdbuf[241]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:16:55 bela stdbuf[241]: make: *** [runonly] Error 139
    Nov 03 17:16:55 bela stdbuf[241]: make: Leaving directory '/root/Bela'
    Nov 03 17:16:55 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:16:56 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:16:56 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:16:56 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:16:56 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:16:56 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:16:56 bela stdbuf[497]: make: Entering directory '/root/Bela'
    Nov 03 17:16:56 bela stdbuf[497]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287779 s in the future
    Nov 03 17:16:56 bela stdbuf[497]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:16:56 bela stdbuf[497]: backtrace() returned 0 addresses
    Nov 03 17:16:56 bela stdbuf[497]: Csound tidy up: Segmentation fault
    Nov 03 17:16:57 bela stdbuf[497]: bash: line 1:   525 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:16:57 bela stdbuf[497]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:16:57 bela stdbuf[497]: make: *** [runonly] Error 139
    Nov 03 17:16:57 bela stdbuf[497]: make: Leaving directory '/root/Bela'
    Nov 03 17:16:57 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:16:57 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:16:57 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:16:57 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:16:57 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:16:57 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:16:57 bela stdbuf[530]: make: Entering directory '/root/Bela'
    Nov 03 17:16:58 bela stdbuf[530]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287778 s in the future
    Nov 03 17:16:58 bela stdbuf[530]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:16:58 bela stdbuf[530]: backtrace() returned 0 addresses
    Nov 03 17:16:58 bela stdbuf[530]: Csound tidy up: Segmentation fault
    Nov 03 17:16:59 bela stdbuf[530]: bash: line 1:   556 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:16:59 bela stdbuf[530]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:16:59 bela stdbuf[530]: make: *** [runonly] Error 139
    Nov 03 17:16:59 bela stdbuf[530]: make: Leaving directory '/root/Bela'
    Nov 03 17:16:59 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:16:59 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:16:59 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:16:59 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:16:59 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:16:59 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:16:59 bela stdbuf[564]: make: Entering directory '/root/Bela'
    Nov 03 17:16:59 bela stdbuf[564]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287776 s in the future
    Nov 03 17:17:00 bela stdbuf[564]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:00 bela stdbuf[564]: backtrace() returned 0 addresses
    Nov 03 17:17:00 bela stdbuf[564]: Csound tidy up: Segmentation fault
    Nov 03 17:17:00 bela stdbuf[564]: bash: line 1:   590 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:00 bela stdbuf[564]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:00 bela stdbuf[564]: make: *** [runonly] Error 139
    Nov 03 17:17:00 bela stdbuf[564]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:00 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:00 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:00 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:01 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:01 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:01 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:17:01 bela stdbuf[595]: make: Entering directory '/root/Bela'
    Nov 03 17:17:01 bela stdbuf[595]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287774 s in the future
    Nov 03 17:17:01 bela stdbuf[595]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:02 bela stdbuf[595]: backtrace() returned 0 addresses
    Nov 03 17:17:02 bela stdbuf[595]: Csound tidy up: Segmentation fault
    Nov 03 17:17:02 bela stdbuf[595]: bash: line 1:   624 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:02 bela stdbuf[595]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:02 bela stdbuf[595]: make: *** [runonly] Error 139
    Nov 03 17:17:02 bela stdbuf[595]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:02 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:02 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:02 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:02 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:02 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:02 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:17:03 bela stdbuf[629]: make: Entering directory '/root/Bela'
    Nov 03 17:17:03 bela stdbuf[629]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287772 s in the future
    Nov 03 17:17:03 bela stdbuf[629]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:04 bela stdbuf[629]: backtrace() returned 0 addresses
    Nov 03 17:17:04 bela stdbuf[629]: Csound tidy up: Segmentation fault
    Nov 03 17:17:04 bela stdbuf[629]: bash: line 1:   655 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:04 bela stdbuf[629]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:04 bela stdbuf[629]: make: *** [runonly] Error 139
    Nov 03 17:17:04 bela stdbuf[629]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:04 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:04 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:04 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:04 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:04 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:04 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:17:04 bela stdbuf[660]: make: Entering directory '/root/Bela'
    Nov 03 17:17:05 bela stdbuf[660]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287770 s in the future
    Nov 03 17:17:05 bela stdbuf[660]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:05 bela stdbuf[660]: backtrace() returned 0 addresses
    Nov 03 17:17:05 bela stdbuf[660]: Csound tidy up: Segmentation fault
    Nov 03 17:17:06 bela stdbuf[660]: bash: line 1:   686 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:06 bela stdbuf[660]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:06 bela stdbuf[660]: make: *** [runonly] Error 139
    Nov 03 17:17:06 bela stdbuf[660]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:06 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:06 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:06 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:06 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:06 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:06 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:17:06 bela stdbuf[691]: make: Entering directory '/root/Bela'
    Nov 03 17:17:06 bela stdbuf[691]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287769 s in the future
    Nov 03 17:17:07 bela stdbuf[691]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:07 bela stdbuf[691]: backtrace() returned 0 addresses
    Nov 03 17:17:07 bela stdbuf[691]: Csound tidy up: Segmentation fault
    Nov 03 17:17:07 bela stdbuf[691]: bash: line 1:   717 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:07 bela stdbuf[691]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:07 bela stdbuf[691]: make: *** [runonly] Error 139
    Nov 03 17:17:07 bela stdbuf[691]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:07 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:07 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:07 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:07 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:07 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:07 bela systemd[1]: Started Run Bela at boot.
    Nov 03 17:17:08 bela stdbuf[722]: make: Entering directory '/root/Bela'
    Nov 03 17:17:08 bela stdbuf[722]: make: Warning: File 'libraries/UdpClient/build/UdpClient.d' has modification time 189287767 s in the future
    Nov 03 17:17:08 bela stdbuf[722]: Running bash -c belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10  -X0 2>&1
    Nov 03 17:17:08 bela stdbuf[722]: backtrace() returned 0 addresses
    Nov 03 17:17:08 bela stdbuf[722]: Csound tidy up: Segmentation fault
    Nov 03 17:17:09 bela stdbuf[722]: bash: line 1:   752 Segmentation fault      belacsound --csd=/root/Bela/projects/27_Ossos_Nov_2022/_main.csd -p16 -C4 -B16 -N0 -G1 -M0 -H0,-6 -H1,-6 -H2,-6 -H3,-6 -H4,-6 -H5,-6 -H6,-6 -H7,-6 -I0,10 -I1,10 -I2,10 -I3,10 -I4,10 -I5,10 -I6,10 -I7,10 -X0 2>&1
    Nov 03 17:17:09 bela stdbuf[722]: Makefile:612: recipe for target 'runonly' failed
    Nov 03 17:17:09 bela stdbuf[722]: make: *** [runonly] Error 139
    Nov 03 17:17:09 bela stdbuf[722]: make: Leaving directory '/root/Bela'
    Nov 03 17:17:09 bela systemd[1]: bela_startup.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
    Nov 03 17:17:09 bela systemd[1]: bela_startup.service: Unit entered failed state.
    Nov 03 17:17:09 bela systemd[1]: bela_startup.service: Failed with result 'exit-code'.
    Nov 03 17:17:09 bela systemd[1]: bela_startup.service: Service hold-off time over, scheduling restart.
    Nov 03 17:17:09 bela systemd[1]: Stopped Run Bela at boot.
    Nov 03 17:17:09 bela systemd[1]: bela_startup.service: Start request repeated too quickly.
    Nov 03 17:17:09 bela systemd[1]: Failed to start Run Bela at boot.
    Can you tell me what the state of the digital inputs is when the board powers up? I.e.: I assume you connected some buttons to each of them, are the digital inputs normally high or low when the buttons are not pressed?
    I have 10 capacitive sensors connected to the digital ports and two relays. They should be low at start.
    can you try installing csound 6.18 from here to see if that fixes it? Copy it to the board and run dpkg -i csound-6.18.11-Linux.deb to install
    Thanks. The link seams not to work.
    4 days later
    I finally managed to update to csound 6.18 and it works! Thanks for your help!
    Great I will make that the official release then
      One more thing i was wondering: I always used to work with firefox to access the IDE. Is there any advantage using Google Chrome? Is there any known issue with firefox?
        luis Is there any known issue with firefox?
        no. If you see "Chrome" somewhere in our docs is mostly legacy
        2 months later
        Thanks for the useful tip - I was seeing the same problem where my Csound projects selected to run on boot would fail with a Segmentation fault.
        I can confirm that upgrading to csound 6.18 from the link above has resolved this issue.
        Cheers
        7 days later
        Hey I have a similar issue that goes off in a different direction.
        My Pepper/Bela is confused.
        I can't get any program to run. I see all the examples in the browser in the IDE. But for example trying to run \example Digital/digital-input/render.cpp I get the following:
        Building project ...
        Building render.cpp...
        Makefile:494: recipe for target '/root/Bela/projects/exampleTempProject/build/render.o' failed
        Build finished
        sh: printf: I/O error
        mkdir: cannot create directory '/root/Bela/projects/exampleTempProject/build': No space left on device
        mkdir: cannot create directory '/root/Bela/projects/exampleTempProject/build/': No space left on device
        error: unable to open output file '/root/Bela/projects/exampleTempProject/build/render.ii': 'No such file or directory'
        error: error opening '/root/Bela/projects/exampleTempProject/build/render.d': No such file or directory
        2 errors generated.
        make: *** [/root/Bela/projects/exampleTempProject/build/render.o] Error 1
        Then other examples I click on I get Error: ENOSPC: no space left on device, write
        Downloaded bela master zip and tried running update_board.sh and I get this:
        Last login: Sun Jan 15 20:27:17 on ttys000
        /Users/michaelschulze/Downloads/Bela-master/scripts/update_board ; exit;
        The default interactive shell is now zsh.
        To update your account to use zsh, please run chsh -s /bin/zsh.
        For more details, please visit https://support.apple.com/kb/HT208050.
        MacBook-Pro-(2):~ michaelschulze$ /Users/michaelschulze/Downloads/Bela-master/scripts/update_board ; exit;
        DATE=2023-01-16T03:39:51Z
        FILENAME=Bela-master
        METHOD=update_board
        Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ECDSA) to the list of known hosts.
        done
        Board found at root@192.168.7.2
        Updating the Bela core code in root@192.168.7.2:/root/Bela
        All the changes to the CORE files in the remote folder /root/Bela will be LOST. The content of these files/folders will be lost:
        core include Makefile Makefile.libraries Makefile.linkbela examples Doxyfile scripts resources pru libraries
        Your projects stored in /root/Bela/projects should be safe (and surely you have already backed them up somewhere safe, haven't you?).
        Are you sure you want to continue? (y/N) y
        Updating Bela core files to remote folder /root/Bela
        Stopping Bela...done
        Updating files......done
        make: Nothing to be done for 'library'.
        make: Entering directory '/root/Bela/resources/tools/bela-cape-btn'
        make: Leaving directory '/root/Bela/resources/tools/bela-cape-btn'
        make: Entering directory '/root/Bela/resources/tools/board_detect'
        cp board_detect /usr/local/bin/
        make: Leaving directory '/root/Bela/resources/tools/board_detect'
        make: Entering directory '/root/Bela/resources/tools/mcasp-dump-tool'
        cp mcasp-dump-tool /usr/local/bin/
        make: Leaving directory '/root/Bela/resources/tools/mcasp-dump-tool'
        done
        An error occurred.
        logout
        Saving session...
        ...copying shared history...
        ...saving history...truncating history files...
        ...completed.
        [Process completed]
        Tried update Bela from the IDE, navigated to Bela-master.zip, I get this:
        Beginning update - this may take several minutes
        The browser will temporarily disconnect, and may become unresponsive
        Do not use the IDE during this process
        Upload completed, saving update file...
        It hangs at this stage so I refresh browser and get:
        Initialise...
        Error: ENOSPC: no space left on device, write Error: ENOSPC: no space left on device, write
        Help? 🙂
        Ram out of space on disk... Were you running a program at boot that produced a lot of text for a long time?
        I suggest starting with running this in the console at the bottom of the Bela IDE:
        rm -rf /var/log /var/cache /root/_*
        Then reboot and run df -h / to see how much space has freed up. You can also look at du -h /root/Bela/projects/ | sort -h to see if any of your Bela projects are taking up a lot of space.
        a month later
