Thanks! Some success. I just changed wscript file directly from c17 to c11 and it now seems to build and install correctly.
I run the journalctl command and it reports following when plugging in
'Nov 12 05:47:49 bela serialoscd[17492]: serialosc [m1001113]: connected, server running on port 19852'
when unplugging it reports
'Nov 12 05:48:09 bela serialoscd[17492]: serialosc [m1001113]: couldn't write config :(
Nov 12 05:48:09 bela serialoscd[17492]: serialosc [m1001113]: disconnected, exiting'
Not being able to write config is a problem now as see I need to edit this file to fix port address. I see the ~/.config hidden folder but clearly no config is written there
if I run serialoscd it has made a serialosc folder under config but unplugging device does not generate the appropriate .conf file
