Hi there,
during my experiments I guess, I killed two of my Trill bars. Thus I wanted to check if its possible to repair them or try to find out the issue.
Number one should be simple, during desoldering of the connector I put to much force on it and removed the pad. So I guess using the "rest" for VCC might work, right?
Number two is a bit harder. I had it connected with adhesive tape and when I removed it, I guess I scratched the wires as you can see in the picture. When I try to use it, its no longer found. Or is this unlikely and might be something else? Is there anything I can try to measure or check?
Thanks for your help and great product!!! Still working on my next controller.
