plate-of-shrimp But now OSC and hardware knobs might not play nice together.
it's hard to make that work smoothly without encoders and many LEDs ...
plate-of-shrimp Well, maybe it was that it would be nice to read the layout file and generate code that could be dropped into a C++ project to provide objects to talk to using a small support library that is prepared for the generated code.
not sure I understand what you mean there
Um, drop the 'small support library' bit, that probably confuses things. The idea is only to extract things from the layout and make C++ representations of them for convenience. Say, that a fader that goes from 0-7 and is called '/coolness/factor' becomes some code you don't have to repetitively write to help wire things up. Using OscReciever and OscSender are easy, and writing a receive callback is easy, so it may not worth the effort.
7 days later
Added delay line.
https://github.com/rhaleblian/transmogriFX_bela/tree/osc
Exposed effects:
- compressor
- klingontone
- overdrive
- chorus
- delay
- reverb (only partially)
Sustainer has a layout but the wiring is not done.
@giuliomoro the files
https://github.com/rhaleblian/transmogriFX_bela/blob/osc/src/osc.cpp
https://github.com/rhaleblian/transmogriFX_bela/blob/osc/src/osc_delay.cpp
show a class abstraction for a virtual "faceplate".
Re: TouchOSC examples, how about something that is in line with the existing examples but replaces eg a pot with a TouchOSC screen? I could make that.
Nice !
Out of curiosity, what makes you prefer TouchOSC over the Bela GUI?
I should try the GUI. I suppose that if it runs in a browser it is portable, in the physical sense? On a phone or tablet?
I may move from TouchOSC to a hardware controller if I see one that does OSC.
Also brings up the question of stomp switch pedalboards, have not looked to see what's out there.
I also got Trills in the mail recently...
    This video showing the screens came out not so well, but I hope it gives a sense.
    I'll record something with sound but it's a little too early here for lots of noise.
    plate-of-shrimp suppose that if it runs in a browser it is portable, in the physical sense? On a phone or tablet?
    yes! although I must say that your TouchOSC solution looks very good already.
    plate-of-shrimp a hardware controller if I see one that does OSC.
    nice, do they exist?
    plate-of-shrimp sound is bit high in the mix.
    indeed, but cool video anyhow
    plate-of-shrimp Also brings up the question of stomp switch pedalboards, have not looked to see what's out there.
    I know there are MIDI boards out there. I played with a Behringer FCB1010 using a USB-Midi converter in Rakarrack on a laptop. It would probably take some coding to pipe the USB-Midi device into Bela, but if you got that working then it would open up a lot of possibilities for HW controllers.
    Another idea i have tossed around is I have an Acer Spin5, which is plenty of screen to support a nice control interface, and is trivial to get MIDI messages through the standard Alsa driver. The control interface including control to a HW MIDI controller via USB in the laptop could send messages to Bela via OSC.
    I would think a tablet with a USB port could be used in the same way. For that matter a Raspberry pi could be used to bridge the MIDI->USB->Network interface and then you could turn any HW MIDI controller into a HW->OSC controller.
    Well there's some brain dump 😉 .
      2 years later
