It seems the original question got lost...
The new image should have the UGens AnalogIn, AnalogOut, etc... so naming without the *put at the end, to match the naming of SoundIn, In, etc. in SC.
And these versions can be run at controlrate directly, so if you do not need things to run at audiorate you can slow them down by using .kr; that removes the need for A2K.
