• Interactivity
  • RapidLib on Bela for embedded interactive machine learning
I have started exploring RapidLib for doing 'IML' on Bela
https://github.com/jarmitage/RapidLibBela
I added a "release" uploading my built files so that others could try it: https://github.com/jarmitage/RapidLibBela/releases/tag/v0.1.0-bela
But when I try this myself on another Bela (running the same image and IDE, and with the appropriate Make Params) it says that it can't find librapidLib.so. I changed the permissions of the whole dir with chmod -R +x RapidLib but that didn't help.
Is there some other reason why another Bela can't use the library built on another device?
    jarm Is there some other reason why another Bela can't use the library built on another device?
    no. But there may be reasons why the library cannot be found. Where do you place the library? You will need to place it in one of the usual places (e.g.: /usr/local/lib ) and run ldconfig after that to rebuild the library cache.
    • jarm replied to this.
      giuliomoro ahhh jeez forgot the ldconfig, it was probably that...!
      Indeed you were correct! Updated the README
