Hi Lokki,
It took me a whole week but I finally got around to doing this. It is not verified (I should at least print one and make sure that the size matches a Trill craft) but the margin of error *should be small because I made the footprint from the PCB itself and looks good on the renders.
I will push it to a GitHub repo once I manage to verify/test it, but feel free to experiment (do cross-check on a printed version though). I added the STEP file for the exported board there as it can be used for the 3D renders if the path is added to the footprint on the PCB to see height, etc.
Here is the link:
Do you think that having an alternate version with mounting holes would be useful? Those were meant for using stands when wires are soldered to it and I think there is enough stability with the headers, but I am open to suggestions.
Let me know if something doesn't work as expected.
Best,
Adan
(I'll reply to your other Trill post later today 🙂)
