H all, I've just asked for the BOM that's in the github link of the build guide. I realized that the capacitors are for the past build (rev2) At least the 220pF are 150pF in the mouser basket. Is ok if I use those? or is it better that I purchase the other ones that are suggested in the build guide Rev2b?
best
a_G you will be fine to use the 220pF instead but please check that the resistor values are also correct as there was a slight change between rev2 and rev2b. Are you using 100K pots?
bela_robert Hi, thanks for the reply. Ok I will check, yes I'm using 100k pots from Thonk. I think if that cart is the reference BOM to buy it would be nice an update, in github i know how to suggest one, but from mouser i don't : /
updated now, thanks.
