After testing the basic Arduino print sketch successfully, I've been trying to test the Processing sketch. I've setup the port etc but as soon as I touch the sensor the sketch crashes and fires the below error. It looks like it might be an OSX issue. I'm running osx10.4, is there any fix for this without updating OS?
Opening port /dev/cu.usbmodem14501
dyld: lazy symbol binding failed: Symbol not found: ___darwin_check_fd_set_overflow
Referenced from: /private/var/folders/9l/2sc8k_5n72ddhcs80vcwnb7c0000gn/T/nativelib-loader_931331348411065053/libjssc.dylib (which was built for Mac OS X 11.0)
Expected in: /usr/lib/libSystem.B.dylib
dyld: Symbol not found: ___darwin_check_fd_set_overflow
Could not run the sketch (Target VM failed to initialize).
For more information, read Help → Troubleshooting.
