• Trill
  • craft accordion style controller
By reading the blog posts on the bela site for craft I am now under the impression, that more then 1 touch is not straight forward with my proposed setup (since the arrangement will be roughly similar to a trill square)
so how is multitouch done on a touchscreen?
    I had an idea for multitouch which I never tried to implement but might work.
    So the trill squares output values for X and Y. If there are multiple peaks on X and Y, you don't really know which X corresponds to which Y. However, if one X peak and one Y peak appeared and another appeared later, you can make an assumption about which peaks form a touch together.
    I made quick drawing in paint to illustrate. As you can see first there is only one peak. We can mark those peaks as A. In a later scanning of the sensors another peak shows up. We now assume the peaks previously known as A still correspond to each other and thus the new peaks must together form touch B.
    This would fail if more than one new touch would appear in a single reading, but depending on how the instrument is played might work.
      Ward However, if one X peak and one Y peak appeared and another appeared later, you can make an assumption about which peaks form a touch together.
      That's an approach that could work in principle, but it may become significantly complicated reasoning to get this to work fine in all cases. A first issue is when two touches have a similar (e.g.🙂 Y value: your spatial accuracy on the Y axis will be limited because the capacitance from the two touches will interfere with each other and you won't be able to distinguish their individual contributions. Second, if touches are starting with clearly distinct values of X and Y, if they move so that they have similar values of (e.g.🙂 Y, you will have similar issues to the previous case, but - more crucially - when they move again so that they are now two distinct touches on Y, you will no longer know which Y value corresponds to which X value. With enough work (and spatial and temporal resolution), this could be made to work well in a controlled set of cases, but the reason why we don't advertise Trill Square and Hex as multitouch is precisely that it is hard (impossible?) to make it work well in all cases.
      lokki so how is multitouch done on a touchscreen?
      Normally it's done with mutual capacitance sensors. A suggestion right there for a new line of Trill sensors 🙂
      Anyhow, I think that in your case here you may be fine with your matrix idea as the two drawbacks I highlighted above shouldn't matter:
      • spatial accuracy ('first') is not an issue because positions are quantised
      • moving touches ('second') is not an issue because you are not sliding between keys (are you?) and anyhow you probably wouldn't care about "what finger is where" (i.e.: touch tracking over time), but rather only "what keys are currently pressed"
      So, as long as you don't press two buttons at "exactly" the same time (i.e.: within one sampling interval of the Trill and read interval from the host), you should be able to track what X value is associated with what Y value. Default sampling intervals on Trill are between 5ms and 7ms I think, but you can make it significantly faster by reducing the bit depth (see here).
        4 days later
        thanks for the input giuliomoro, i built a 10x17 matrix with two layers of conductive tape. i started hooking it all up but realised that i need the physical feedback of a "real" button. (as @bela_robert suggested before) so i switched all buttons to paper fasteners on my previous model, the golden ones have a brass coating and solder easily. will post a picture later.
        however i would still like to build a square like controller to use with my feet (barefoot i guess, since it won't work with shoes).
        what is the best pattern to get a trill square behaviour from a trill craft (25cmx25cm sensing area)?
        is there a way to run the square firmware on a craft? or do i need to emulate the behaviour on the receivers end?
        would it be 15 zigzags and 15 zigzags as a second layer rotated by 90 degrees? how much space between the individual copper zigzags?
        what is the pattern on the square? from the pictures it looks like straight lines, but that does not make too much sense i think.
        Looking great!
        Recreating a Trill Square from a Craft is a bit more tricky than recreating a Bar as you need each of the rows and columns of the matrix to be interlocking whilst being insulated from one another.
        On Trill Square we have a number of diamond-shaped pads on the top sensing side. This is actually of array of 15 x 15 diamonds. In one direction (down the columns) you can see that all the diamonds are connected from bottom corner to tip of the diamond below. Going across the rows the diamonds are connected via a series of vias in PCB which "weave" these two axes together. Here's a diagram illustrating that:
        Achieving something similar to this with DIY manufacturing techniques is tricky but not impossible – personally I'd recommend using some kind of computer aided cutting of the copper tape to get a consistent pattern.
        For inspiration check out this project: https://dl.acm.org/doi/10.1145/3332165.3347895 Works in a very similar way to Trill Craft so you can just imagine your connections being made directly to the Craft channels. If you look at the second video on that page at 1.45 there is an example of cutting a pattern for the rows in copper tape using a cutter machine, fixing it to the sensing surface and then coating in PLA as an insulator, then adding a similar pattern for the columns.
        All this said, you can probably get semi decent results by simply weaving copper tape with an insulated backing together so the columns and rows intersect. Worth trying this simple solution first. You will need to apply some filtering to the readings as the shapes are not ideal but it could be all you need for your use case.
        Regarding running the firmware for Square on a Craft, that's not possible without reflashing the chip on the Craft. But it's not necessary to do this to get the Craft to behave like a Square. You can use our CentroidDetection library for this. Have a look at the custom-slider example in the Trill folder. Here you can define the exact pin numbers and their order for each axis. You can then apply the centroid detection on that custom array of pins.
        thanks, that's perfect to get me started.
        here are some pics of my "accordion" controller. one half is hooked up to a craft, the other one still to do.
        paper fasteners are the sh*t!
          lokki paper fasteners are the sh*t!
          how are they more "button-feely" than the upholstery nails?
            giuliomoro they are not.
            but the upholstery nails were a pain to solder to and connections kept breaking again and again while playing. Also the ones I had were a bit too big for my layout so that my fingers would sometimes slip to another one as well (hard to explain)
            Also the paper fasteners are self-holding and dirt-cheap.
            13 days later
            here is an update..both crafts connected, printed some "white" key markers to make orientation possible/easier. still undecided if i want to print black ones too, or leave it as is. 3 fsrs underneath the controller to get aftertouch, works great so far.
            9 months later
            it is still working fine in my midi-bass. I added some black key-rings as well, and the last two inputs on one of the crafts were used for selecting the keyboard mode (midi-channel, note mode, program change mode). I also added a small oled to show the selected mode. based on how fast a finger approaches the sensor I also calculate a velocity value but that works not very consistently.
              lokki based on how fast a finger approaches the sensor I also calculate a velocity value but that works not very consistently.
              Here's a few suggestions you may find useful:
              • lower the bit rate. This will allow for faster scanning, which is crucial to get velocity.
              • tweak the prescaler. By reducing its value the "gain" of the detector is increased and so the pad will saturate more quickly. On the other hand, this increases the sensitivity, so it gives higher (and so perhaps more meaningful) values while you are approaching the pad
              • when reading trill repeatedly you may re-read the very same set of sensor readings multiple times, unless you are reading only in response to an event on the event pin. If you are reading the same set of sensor readings multiple times, make sure you distinguish between repeated and non-repeated ones and only use non-repeated ones in your velocity detector. There is no built-in way to distinguish between repeated and non-repeated ones, but you can easily do so by checking the new readings with the previous ones: if they are exactly the same, they are repeated.
                Hi, very nice instrument. I'm in a similar process right now of building a guitar with 6 Trill craft and Bela and Pd. I thought about a way to read velocities out of the pads but didn't know if it was possible or how to do it. Can I ask how you do it?
                To estimate velocity you'd need to look at the readings when the touch starts and compute the difference between successive readings. This will give an estimate of the velocity.
                14 days later
                giuliomoro There is no built-in way to distinguish between repeated and non-repeated ones,
                I'm adding that to the next firmware. Also adding a way to reduce transfer and scanning times by disabling unneeded channels and packing the results in fewer bits.
                2 months later
                Wow...very nice!!! A lot of work into this.
                a month later
                The next generation of Trills will hopefully use mutual capacitance-capable chips ... but we have no concrete roadmap for that yet.
