in an emergency situation such as this one you can normally free a sizeable amount of space with
rm -rf /var/cache/apt /var/log
then if you are using an SD card you should probably consider enlarge its filesystem to take up all available space, see here https://learn.bela.io/using-bela/bela-techniques/managing-your-sd-card/#resizing-filesystems-on-an-existing-sd-card .
haK I get the "Error: ENOSPC: no space left on device, write" even when I just want to replace samples with the same or lesser file size.
this specific error could be due to the internals of how the old file is deleted after the new one is copied. You may want to try and delete it before uploading the new one. It may also You may also have something
left in /root/Bela/uploads, so try rm -rf /root/Bela/uploads.
haK Wasn't there a command line in order to reset or rebuild the directory without deleting anything?
Well, you could update the Bela code on your board without deleting the projects, but if you have a bunch of large files in the projects that won't fix anything.
You could try du -sh /root/Bela/projects/* to see if any project is unexpectedly using a lot of space.
