No program set to running on boot. The usual lights are blinking and BELABOOT partition is on the
desktop. Here's the ifconfig post:
Christophers-MacBook-Pro:~ chrisbrown$ ifconfig
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
XHC20: flags=0<> mtu 0
ether a4:5e:60:eb:4a:45
inet6 fe80::43d:fecb:2e5c:70fa%en0 prefixlen 64 secured scopeid 0x5
inet 192.168.4.23 netmask 0xfffffc00 broadcast 192.168.7.255
media: autoselect
status: active
ether 06:5e:60:eb:4a:45
media: autoselect
status: inactive
ether 7e:65:82:aa:83:ce
inet6 fe80::7c65:82ff:feaa:83ce%awdl0 prefixlen 64 scopeid 0x7
media: autoselect
status: active
options=60<TSO4,TSO6>
ether 6a:00:02:97:c9:00
status: inactive
ether 6a:00:02:97:c9:01
status: inactive
Configuration:
ipfilter disabled flags 0x2
ifmaxaddr 0 port 8 priority 0 path cost 0
ifmaxaddr 0 port 9 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::77af:c8e9:d132:60c6%utun0 prefixlen 64 scopeid 0xb
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::af25:3d10:3a27:31cf%utun1 prefixlen 64 scopeid 0xc
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::216b:16af:2f18:8103%utun2 prefixlen 64 scopeid 0xd
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::3c98:fa20:e3bd:32f2%utun3 prefixlen 64 scopeid 0xe
en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether be:1a:25:3e:cb:a8
inet6 fe80::ff:79cf:dc55:fe55%en7 prefixlen 64 secured scopeid 0xf
inet 192.168.7.1 netmask 0xffffff00 broadcast 192.168.7.255
status: active
    cbmuse en7: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
    status: active
    this is the Bela network, already with the correct IP address. Can you try again to connect to 192.168.7.2 in a browser? Failing that, try the following in the terminal:
    ping -c 5 192.168.7.2
    ssh -o ConnectTimeout=3 root@192.168.7.2 exit
    If this works fine, let's see what went wrong, print the output of:
    ssh root@192.168.7.2 "ls && cat ~/update.log"
    unfortunately Bela image v0.3.8e (shipped between November 2021 and January 2022) shipped with a broken update procedure, so it may have missed the last mv step.
    I thought it worked, but still not able to reconnect even after rebooting Bela.
    There was a massive reply to ssh command ending with this:
    Creating directory structure on the board...done
    Generating on-board documentation...done
    Warning: this script will DELETE any existing IDE files from your board and install the IDE. Continue? (y/N) y
    Copying new IDE files to the board...using rsync...done
    Rebuilding node dependencies...done
    The IDE was correctly updated
    Setup complete.
    Core setup complete.
    SUCCESS=true
    Restoring directory structure...
    Kill the IDE
    Stopping currently running IDE...done
    Can you show the first line of the output? Namely, the output of
    ssh root@192.168.7.2 ls
      Oh and also
      ssh root@192.168.7.2 grep v0 /etc/motd
      so, try this:
      ssh root@192.168.7.2 mv _BelaUpdateBackup Bela
      then, download this, unzip it on your computer and run the program scripts/update_board.
      great, it's all back and working again -- thanks!
      while i've got you on the line, would you be able to describe what happened here and which of the steps that you gave me were essential for fixing it? my guess is: first you checked to make sure that the board was functioning enough to connect to the host correctly, next made sure that it wasn't a faulty startup program that I installed. Then you checked for the faulty update procedure -- was that the problem? I'm gessing the mv _BelaUpdateBackup Bela line is where you started to replace it? And then the update_board script replaced it?
      After the couple of sessions you've talked me thru, I'm feeling like the Bela environment is fairly fragile since I don't have much linux experience and was hoping that I could do my projects with my SuperCollider chops alone. So just trying to learn, and I'll save all your replies to help for the next time it might happen!
      Chris
        I think what happened is that the version of the core code that was on your board was one that had trouble updating and failed at the very last step of the update (when mv _BelaUpdateBackup Bela should happen). So the fix finished the update, and the board was probably ready as it was, but as a I was unsure about the state of the board, I let you run update_board again, just in case.
        cbmuse it wasn't a faulty startup program that I installed.
        a CPU-intensive startup program would slow down the loading of the IDE after boot.
        Hopefully the board won't have more problems going forward, unless I break something else. 😛
