Hello everyone,
I'm having issues with the Trill Craft. I wanted to use its capacitive touch capabilities and use copper tape as an interaction point for an exhibition. I'm working with Pure Data, but every time I hook everything up and run the "capacitive sensing" example patch, it tells me:
Unable to identify device
Unable to create Trill CRAFT device `mycraft` on bus 1 at default address. Is the device connected?
bela_setTrill sensor_id unknown: mycraft
I'm not sure what the issue is. I assumed the default patch would work automatically as long as everything is hooked up, and I indeed have everything set up as in the example image here: https://learn.bela.io/assets/images/fritzing/pd//capacitive-sensing.png.
Does anyone know what the issue might be? Thank you for your time!
