thanks, it seems i cannot find the add8704 at mouser anymore.
the BOM mentions OPA4348AIPWR but they are on backorder...64 weeks. jeez.
what is the non connected jumper on the input stage (the one that connects r2 to pin2 for example)? optional gain?
if i were to use the audio-expander, i don't suppose it is easy to mod it for more analog gain and lower cutoff on the lowpass. basically i need four inputs with cutoff frequency at
E: 131HZ
A:175HZ
D: 233HZ
G: 311HZ
EDIT: and the same question goes for the bela-mini-multi:
any analog gain stage that i can use? and i guess i would still need to create a lowpass filter upfront.
although, maybe with a higher quality signal i could do that digitally...
