Thanks! below are the prompts and replies -- and I haven't yet developed the program
to run on boot but will start using the SuperCollider sample programs for AnalogIn and AnalogOut
ls /dev/tty.* /Volumes
/dev/tty.Bluetooth-Incoming-Port /dev/tty.ChrisBrownsiPad-Wireles
/dev/tty.Chris-WirelessiAP /dev/tty.ChristophersMacBookPro-
/dev/tty.Chris-WirelessiAP-1 /dev/tty.JacketH204-SerialPort
/Volumes:
Macintosh HD
chrisbrown@cbMacMini ~ %
ifconfig
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
options=50b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV,CHANNEL_IO>
ether f0:18:98:f3:16:bb
inet6 fe80::4ae:8e6e:6ae7:8085%en0 prefixlen 64 secured scopeid 0x4
inet 192.168.4.24 netmask 0xfffffc00 broadcast 192.168.7.255
media: autoselect (1000baseT <full-duplex,flow-control,energy-efficient-ethernet>)
status: active
en10: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether ac🇩🇪48:00:11:22
inet6 fe80::aede:48ff:fe00:1122%en10 prefixlen 64 scopeid 0x5
status: active
ap1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 3e:22:fb:1e:9d:bd
media: autoselect
status: inactive
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 3c:22:fb:1e:9d:bd
inet6 fe80::1c8c:cb40:5f3d:aa11%en1 prefixlen 64 secured scopeid 0x7
inet 192.168.4.25 netmask 0xfffffc00 broadcast 192.168.7.255
media: autoselect
status: active
ether 0e:22:fb:1e:9d:bd
media: autoselect
status: inactive
ether 4a:f7:52:cb:c2:93
inet6 fe80::48f7:52ff:fecb:c293%awdl0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
inet6 fe80::48f7:52ff:fecb:c293%llw0 prefixlen 64 scopeid 0xa
media: autoselect
status: active
ether 82:77:b4:67:20:01
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:77:b4:67:20:00
status: inactive
en4: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:77:b4:67:20:05
status: inactive
en5: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 82:77:b4:67:20:04
status: inactive
Configuration:
ipfilter disabled flags 0x0
ifmaxaddr 0 port 11 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 12 priority 0 path cost 0
member: en4 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 13 priority 0 path cost 0
member: en5 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 14 priority 0 path cost 0
media: <unknown type>
status: inactive
inet6 fe80::5dfe:22a0:675e:7be0%utun0 prefixlen 64 scopeid 0x10
inet6 fe80::906d:647f:8b7c:7f14%utun1 prefixlen 64 scopeid 0x11
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::cf03:fde6:e39:275%utun2 prefixlen 64 scopeid 0x12
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::257e:b7e8:ccbd:98f9%utun3 prefixlen 64 scopeid 0x14
utun4: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::aa59:9e2c:d3a1:bd96%utun4 prefixlen 64 scopeid 0x15
system_profiler SPUSBDataType
2022-03-04 18:24:29.712 system_profiler[5009:217803] SPUSBDevice: IOCreatePlugInInterfaceForService failed 0xe00002be
USB:
USB 3.1 Bus:
Host Controller Driver: AppleIntelCNLUSBXHCI
PCI Device ID: 0xa36d
PCI Revision ID: 0x0010
PCI Vendor ID: 0x8086
USB3.0 Hub:
Product ID: 0x0617
Vendor ID: 0x05e3 (Genesys Logic, Inc.)
Version: 44.27
Speed: Up to 5 Gb/s
Manufacturer: GenesysLogic
Location ID: 0x14800000 / 3
Current Available (mA): 900
Current Required (mA): 0
Extra Operating Current (mA): 0
USB3.0 Hub:
Product ID: 0x0617
Version: 44.27
Speed: Up to 5 Gb/s
Location ID: 0x14840000 / 4
External:
Product ID: 0x0583
Vendor ID: 0x152d (JMicron Technology Corp.)
Version: 4.06
Serial Number: DD564198838A1
Speed: Up to 5 Gb/s
Manufacturer: JMicron
Location ID: 0x14844000 / 7
Current Required (mA): 896
USB2.0 Hub:
Product ID: 0x0610
Version: 44.27
Speed: Up to 480 Mb/s
Location ID: 0x14300000 / 2
Current Available (mA): 500
Current Required (mA): 100
USB Receiver:
Product ID: 0xc52b
Vendor ID: 0x046d (Logitech Inc.)
Version: 24.07
Speed: Up to 12 Mb/s
Manufacturer: Logitech
Location ID: 0x14330000 / 6
Current Required (mA): 98
Fireface UCX (23862324):
Product ID: 0x3fc9
Vendor ID: 0x0424 (SMSC)
Version: 0.01
Serial Number: 8E1F9BAA811A0C8
Manufacturer: RME
Location ID: 0x14310000 / 24
USB2.0 Hub:
Product ID: 0x0610
Version: 44.27
Location ID: 0x14340000 / 5
eLicenser:
Product ID: 0x0101
Vendor ID: 0x0819
Version: 1.01
Manufacturer: Syncrosoft
Location ID: 0x14341000 / 8
USB 3.1 Bus:
Host Controller Driver: AppleUSBXHCITR
PCI Device ID: 0x15ec
PCI Revision ID: 0x0006
Bus Number: 0x01
USB 3.1 Bus:
Bus Number: 0x00
Apple T2 Bus:
Host Controller Driver: AppleUSBVHCIBCE
Headset:
Product ID: 0x8103
Vendor ID: 0x05ac (Apple Inc.)
Version: 2.05
Serial Number: 000000000000
Manufacturer: Apple
Location ID: 0x80200000
Apple T2 Controller:
Product ID: 0x8233
Version: 2.01
Serial Number: 0000000000000000
Manufacturer: Apple Inc.
Location ID: 0x80100000
