That seemed to work! However i dont seem to receive anything on the host. When using the localip, the console kept flooding with osc message formats (which i assume is a good thing). My console is completely empty however, even though the errors dissapeared. Here is the complete output i got after following your steps:
root@bela ~/Bela# sed -i s/OscSenderTask_/OscSndrTsk_/ /root/Bela/libraries/OscSender/OscSender.cpp
root@bela ~/Bela# git diff libraries/OscSender/OscSender.cpp
diff --git a/libraries/OscSender/OscSender.cpp b/libraries/OscSender/OscSender.cpp
index 93ce26c1..480054cc 100644
--- a/libraries/OscSender/OscSender.cpp
+++ b/libraries/OscSender/OscSender.cpp
@@ -29,7 +29,7 @@ void OscSender::setup(int port, std::string ip_address){
socket->setup(port, ip_address.c_str());
send_task = std::unique_ptr(new AuxTaskNonRT());
- send_task->create(std::string("OscSenderTask_") + ip_address + std::to_string(port), [this](void* buf, int size){send_task_func(buf, size); });
+ send_task->create(std::string("OscSndrTsk_") + ip_address + std::to_string(port), [this](void* buf, int size){send_task_func(buf, size); });
OscSender &OscSender::newMessage(std::string address){
Building project ...
Building render.cpp...
...done
Using library OscSender
Using library UdpClient
Building library OscSender
Linking...
...done
Build finished
Running project ...
Mar 02 15:57:19 bela stdbuf[99]: Makefile:597: recipe for target 'runonly' failed
Mar 02 15:57:19 bela stdbuf[99]: make: *** [runonly] Terminated
Mar 02 15:57:19 bela systemd[1]: Stopping Run Bela at boot...
Mar 02 15:57:19 bela systemd[1]: Stopped Run Bela at boot.
