And maybe a new type to the enum is not needed, but looking for the case where a == lastA_ and then dealing with the level transition on b. It's an encoder so there is a transition at every step.
    stgislander Are there any settings in the IDE to change that?
    it may be a browser zoom issue. Try resetting the zoom to 100% and see if that fixes it.
    stgislander And maybe a new type to the enum is not needed, but looking for the case where a == lastA_ and then dealing with the level transition on b. It's an encoder so there is a transition at every step.
    I wrote that class based on some encoders that I had around, for which it worked as expected with one of the enum values. IIRC, the rationale was: wait for a change on a and then look at the level on b to know which way we are turning. The one you have seems to be working differently, do you have a datasheet link?
    Yup, that won't work with current code. Do you need help with fixing it?
    I'm debating if I can get away with (for lack of a better term) double-step operation. My customer wanted to use these for manual setting of operating parameters. The operator will feel every detent click, but only every second click will set anything.
    I've looked at some Arduino code that sets up state machines to count at every step. I'd have to look into seeing if it can be ported over to the Bela/BeagleBone Black.
    What are you thinking the time would be to modify the existing Bela code?
      stgislander What are you thinking the time would be to modify the existing Bela code?
      If one has the encoder at hand, that would be one hour including debugging perhaps. I'd encourage extending the library instead of rolling an entirely different implementation ...
      Good thing I have four of them handy, huh?
      So far I've made the following changes to Encoder.h and Encoder.cpp. I'm going on the assumption that I need to perform the same debounce and edge checking operations on input b as I do on input a. I've commented around the code I've added.
      In Encoder.h I added four new variables to private
      private:
         bool validEdge(bool a);
         unsigned int debouncing_;
         unsigned int debounce_;
         int position_;
         Polarity polarity_;
         bool a_;
         bool lastA_;
         bool primed_;
         //TIM 3-2-22 New
         unsigned int debouncingB_;
         unsigned int debounceB_;
         bool b_;
         bool lastB_;
         //end NEW
      In Encoder.cpp I made the following changes
      void Encoder::setup(unsigned int debounce, Polarity polarity)
         debounce_ = debounce;
         reset();
         polarity_ = polarity;
         debouncing_ = 0;
         primed_ = false;
         //TIM 3-2-22 New
         debounceB_ = debounce;
         debouncingB_ = 0;
         //end NEW
      and
      Encoder::Rotation Encoder::process(bool a, bool b)
         Rotation ret = NONE;
         if(!primed_) {
            lastA_ = a_ = a;
            primed_ = true;
         if(a != lastA_) {
            if(validEdge(a))
               debouncing_ = debounce_ + 1;
            else
               a_ = a;
         //TIM 3-2-22 New
         if(b != lastB_) {
            if(validEdge(b))
               debouncingB_ = debounceB_ + 1;
            else
               b_ = b;
         //end NEW
         // wait for the data to be stable long enough
         // before checking for an updated value
         if(1 == debouncing_ && a_ != a)
            a_ = a;
            if(validEdge(a))
               if(b == a)
                  ret = CCW;
               else
                  ret = CW;
               if(ACTIVE_LOW == polarity_)
                  ret = CCW == ret ? CW : CCW;
               position_ += ret;
         if(debouncing_)
            --debouncing_;
         lastA_ = a;
         //TIM 3-2-22 NEW
         if(debouncingB_)
            --debouncingB_;
         lastB_ = b;
         //end NEW
         return ret;
      That leaves the checking and counting operation in the if(1 == debouncing_ && a_ != a) conditional statement to handle.
      Am I on track, and what are your thoughts on performing checking and counting input b?
      Technically I've made the changes to files on my local PC. I'm guessing the real library files that are used to build programs reside on GitHub?
      For testing purposes, can I point the IDE to modified library files on my PC?
        stgislander I'm guessing the real library files that are used to build programs reside on GitHub?
        no, they are on the board. You can copy your file over with something like
        rsync -av path/to/Bela/libraries/Encoder/Encoder.* root@bela.local:Bela/libraries/Encoder/
        or directly edit the files on the board at /root/Bela/libraries/Encoder/
        When editing a library, you won't automatically trigger a rebuild of the program, so you either need to make a non-meaningful change to the file in your project or add RELINK=1 to the Make parameters box in the project settings in the IDE to automatically rebuild the library (you can remove it later on when you are done with the development).
        Okay I may have a problem. That looks like Unix (yeah I'm that old) to me, and I live in the Windows world.
        Can I do any of that through the IDE?
          stgislander Can I do any of that through the IDE?
          it's complicated. You could also add all the (modified or not) files from the libraries/Encoder folder to the project folder and turn all instances of
          #include <libraries/Encoder/Encoder.h
          to
          #include "Encoder.h"
          and
          #include <libraries/Encoder/BelaEncoder.h
          to
          #include "BelaEncoder.h"
          Thanks. I'll try that.
          I'm also looking for a Linux desktop/laptop, and/or installing Windows Subsystem for Linux (WSL) on my PC as a fallback.
          or install github desktop and it comes with "Git Bash" which should have scp and/or rsync
          So should my modified files still be named Encoder.h and Encoder.cpp, or can I can I rename them to differentiate them from the originals?
          Also, thanks for pointing out the BelaEncoder.* files. I didn't think to look at those.
            stgislander So should my modified files still be named Encoder.h and Encoder.cpp, or can I can I rename them to differentiate them from the originals?
            as you prefer. As long as you don't
            #include <libraries/Encoder/SOMETHING
            then none of the files in libraries/Encoder will be used.
            I prefixed the modified Encoder and BelaEncoder files with "New" to keep me straight. I changed all #include statements to "NewEncoder.h" and "NewBelaEncoder.h". Finally I uploaded two new .cpp and two new .h files into my project folder, and rebuilt them
            The project built successfully, so it appears I can now get back to troubleshooting.
            Success. I need to exercise it more to find any hidden bugs, but it counts at every step. Next is to edit render.cpp to read 2-3 encoders.
            Thanks Giulio.
            Good news! If you have any code worth sharing that could be integrated back in the original library, let us know here or by making a pull request on github.com/BelaPlatform/Bela/pulls
            If you were going to read three different encoders, would you just create three instances of gEncoder?
            For example in render.cpp, something like Encoder gEncoder[3];
