Hi, I'm unable to access Bela (using either http://bela.local/, http://192.168.7.2/ or http://192.168.6.2/).
My Bela shows the heartbeat pattern, and it is running the latest firmware. I'm running MacOS Mojave (10.14.6). Bela is connected through a USB-C hub.
I've Installed HoRNDIS 9.2 and rebooted, but I've not confirmed in some way it is actually installed properly.
ifconfig returns:
inet6 ::1 prefixlen 128
stf0: flags=0<> mtu 1280
XHC20: flags=0<> mtu 0
XHC0: flags=0<> mtu 0
ether 8c:85:90:9c:19:5e
inet6 fe80::10a2:549b:1fd7:7b5f%en0 prefixlen 64 secured scopeid 0x6
inet6 2a02:a210:2102:be00:4dc:5301:6d00:32b1 prefixlen 64 autoconf secured
inet6 2a02:a210:2102:be00:e53b:28e5:4e31:b15f prefixlen 64 autoconf temporary
inet 192.168.178.11 netmask 0xffffff00 broadcast 192.168.178.255
media: autoselect
status: active
ether 0e:85:90:9c:19:5e
media: autoselect
status: inactive
ether 46:0a:fc:66:9f:90
inet6 fe80::440a:fcff:fe66:9f90%awdl0 prefixlen 64 scopeid 0x8
media: autoselect
status: active
options=60<TSO4,TSO6>
ether fe:00:d1:10:26:01
status: inactive
ether fe:00:d1:10:26:00
status: inactive
Configuration:
ipfilter disabled flags 0x2
ifmaxaddr 0 port 9 priority 0 path cost 0
ifmaxaddr 0 port 10 priority 0 path cost 0
media: <unknown type>
status: inactive
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::ca87:f22f:d32f:6a49%utun0 prefixlen 64 scopeid 0xc
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=4<VLAN_MTU>
ether 48:65:ee:17:a7:6d
media: autoselect (none)
status: inactive
