Hello everyone/giuliomoro,
There is something, that really annoys me and also stops me from going on:
I wanted to use the Bela as a guitar pedal, but unfortunately I'm getting a crazy amount
of pink/white noise at the input, when I later amplify the output signal.
To make something clear: When I talk about noise, I mean the "hiss" and not any interference.
I mean there is some white noise at the output, but it's not that significant.
However when I use the input, there is lots of pink/white noise.
I've got the standard BelaBoard (BeagleBoard Black + Bela Cape) and I also added
the pins to the unpopulated pads for LineOut.
I'm powering the Bela over 5V USB (5V Barrel connector gives me digital noise)
So to make it more clear, I've created a simple setup, in order to explain this:
Electronically I did this:
-Left output connected to OutputJack(Tip)
-Audio ground pin connected to OutputJack(Sleeve)
With left output I mean LineOut(L+) xor Headphone Output, I tried both, and they give me the same result.
And with audio ground I mean the ground pins at the BelaCape audio interface.
(The DGND pins are just adding digital noise...)
The Output goes over to my Amp over a simple 6,35mm mono cable (I also tried different lengths of cables, but that
didn't change anything)
Programmatically:
A simple project that just copies the left input to the left output.
Settings:
Block size: 16
Sample Rate: 44100
Headphone Level: 0
DAC level: 0
ADC level: 0
PGA gains: 0
What I get (the volume of my amp is at 1.5):
This is how it sounds like:
I also tried to connect my guitar to the Bela audio input, but the noise wasn't even attenuating.
The right input channel also gives that terrible pink noise.
So my question is: how do i get rid of it?
Is it an impedance problem? Are the parts on the BelaCape PCB correct?
Is it the normal behaviour of the TLV320AIC3104 Audio Codec?
I have no clue.
I love the idea behind Bela and I love the fact, that it provides low latency audio.
I would appreciate any help in getting this fixed!
Thanks.
Greetings from Germany
