Long message, because of the output of the commands....
Mac OS: Yosemite 10.10.5
Drivers are from page, as of last night: http://beagleboard.org/getting-started
EnergiaFTDIDrivers2.2.18.pkg
HoRNDIS.pkg
(on that web page, the version of HoRNDIS is not given, but checking http://joshuawise.com/horndis, and running MD5, I see that the version of HoRNDIS I installed on Feb 2 was rel8 (with support for OSX 10.11); the HoRNDISrel8 on the Bela SD is rel7 which I just installed this morning.
First, booting without SD card:
lights flash
BEAGLEBONE shows up on Desktop, which I can open up in Mac Finder and access files such as:file:///Volumes/BEAGLEBONE/START.htm
I cannot ping 192.168.7.2 nor ssh root@192.168.7.2
ifconfig gives:
$ ifconfig
options=3<RXCSUM,TXCSUM>
inet6 ::1 prefixlen 128
nd6 options=1<PERFORMNUD>
stf0: flags=0<> mtu 1280
en1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 28:cf:e9:66:07:35
inet6 fe80::2acf:e9ff:fe66:735%en1 prefixlen 64 scopeid 0x4
inet 10.0.0.183 netmask 0xffffff00 broadcast 10.0.0.255
inet6 2601:401:2:f6b2:2acf:e9ff:fe66:735 prefixlen 64 autoconf
inet6 2601:401:2:f6b2:6500:a99f:fad1:a20a prefixlen 64 autoconf temporary
inet6 2601:401:2:f6b2::2c76 prefixlen 64 dynamic
media: autoselect
status: active
fw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 4078
lladdr 44:fb:42:ff:fe:3c:4b:48
status: inactive
options=60<TSO4,TSO6>
ether d2:00:13:c4:b4:80
status: inactive
options=10b<RXCSUM,TXCSUM,VLAN_HWTAGGING,AV>
ether 10:dd:b1:c8:f9:48
media: autoselect (none)
status: inactive
ether 0a:cf:e9:66:07:35
media: autoselect
status: inactive
awdl0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1452
ether 1e:c4:7c:ba:34:18
inet6 fe80::1cc4:7cff:feba:3418%awdl0 prefixlen 64 scopeid 0x9
media: autoselect
status: active
ether 2a:cf:e9:66:45:00
Configuration:
ipfilter disabled flags 0x2
ifmaxaddr 0 port 6 priority 0 path cost 0
media: <unknown type>
status: inactive
inet6 fe80::d16e:aaee:1800:eb5%utun0 prefixlen 64 scopeid 0xc
inet6 fd86:26f8:c235:c5a0:d16e:aaee:1800:eb5 prefixlen 64
en3: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1486
ether b0:d5:cc:fd:26:20
inet6 fe80::b2d5:ccff:fefd:2620%en3 prefixlen 64 scopeid 0xa
inet 192.168.7.1 netmask 0xfffffffc broadcast 192.168.7.3
media: autoselect
status: active
Booting with SD card:
lights flash
BELABOOT shows up on Desktop, which I can open up in Mac Finder; opening START.htm takes me to 192.168.7.2 ... successfully
This already better than last night when I tried. However, I still cannot ping 192.168.7.2 nor ssh root@192.168.7.2
ifconfig gives:
$ ifconfig
media: autoselect
status: active
status: inactive
status: inactive
status: inactive
media: autoselect
status: inactive
media: autoselect
status: active
Configuration:
status: inactive
media: autoselect
status: active
It seems like a driver problem, does it not? since though I see BEAGLEBONE and BELABOOT on my Desktop and can access the files via the Finder, but cannot ssh to the BBB.
On the other hand, when I first plugged in the new BBB, before booting from the SD, I just booted without it, and all was well.
Okay, for the "sudo dmesg", immediately after plugging in the board (with the SD card) now, running sudo dmesg
$ sudo dmesg
Password:
.path2 /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/ntpd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/usbd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/nehelper]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/nsurlsessiond]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/networkd_privileged]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/networkd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/awacsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/findmydeviced]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/secinitd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/CryptoTokenKit.framework/ctkd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/PCSC.framework/Versions/A/XPCServices/com.apple.ctkpcscd.xpc/Contents/MacOS/com.apple.ctkpcscd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/Support/coreservicesd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/cfprefsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/diagnosticd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/distnoted]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/notifyd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/taskgated]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/amfid]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/hidd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/KernelEventAgent]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/logind]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/stackshot]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/mDNSResponder]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/autofsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/blued]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/locationd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/securityd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/launchservicesd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/PrivateFrameworks/ApplePushService.framework/apsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/wirelessproxd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/opendirectoryd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/backupd.bundle/Contents/Resources/mtmfs]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/wdhelper]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/coreduetd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/diskarbitrationd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/iconservicesagent]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/iconservicesd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mds]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/warmd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/airportd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/powerd.bundle/powerd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Extensions/Line6Audio.kext/Contents/Resources/L6KSettingMgr]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/appleeventsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/configd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/CoreServices/backupd.bundle/Contents/Resources/mtmd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/thermald]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /opt/cisco/anyconnect/bin/vpnagentd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/kextd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/sbin/syslogd]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /usr/libexec/UserEventAgent]
0 [Level 7] [Facility com.apple.sandbox.telemetry] [com.apple.sandbox.event com.apple.sandbox.event.get-task] [com.apple.sandbox.path /Library/Application Support/iStat local/iStatLocalDaemon] [com.apple.sandbox.path2 /sbin/launchd]
