BitShapeSoft
It's not quite as easy as Arduino to get the serial port working on the BeagleBone. If you google 'BeagleBone UART C++' you will find a few guides on how to do it. The basic idea is that you first enable the UART peripheral from the terminal, and you then open a file (usually /dev/tty01 or similar) corresponding to the serial port and use standard linux calls to write to and read from the port.
With Bela there is the added complication that the linux calls can not be used directly from the audio thread, but must be done from an Auxiliary Task.
Feel free to ask more specific questions if you get stuck. A better way to easily port Arduino libraries to Bela is something I want to look into in the future.
