i was wondering if the trill ring should be linear across a full turn?
i tried simply dividing the position reading by 222 (approximate number i got by dividing the largest reading by 16) to get 16 discrete values, but it seems the numbers are not exactly evenly spread across a 360 degree turn. is there a certain variance from trill ring to another? or is the goal not to be linear?
i can take a lookup table approach or decide what to do with certain readings that are within a range, the dividing option just looked like the (obviously) easiest one :-)
