i think the results and possible applications are somewhat similar to those of a turing machine, for example,
but hopefully different enough to be it's own thing. please try and let me know what you think.
download from the link above and rename _main.pd as usual.
with minimal effort, i guess it could easily be adapted for Salt users (4 CV ins, 2 trigger ins, should be ok, no?).
only the binary outputs would need a compromise - but they already were in the first place, since you would need 14 bit to represent 9232.. and even that value was a conscious limitation.
fun thing to try would be negative input numbers - these can generate different loops in the strings than the 1-4-2-1 end loop, so every now and then you might hit an unexpected LFO
anyway
i had a lot of fun patching this, hope you like it.
