Hi, I am new to Pd and am learning on a Bela I/O. I want to write code so that three separate LDR's attached to the Bela send a signal so that a sound is played at a certain reading. I want the signal to send when the LDR has less light, not more. I was going to use the threshold object but I can only find examples of triggering a signal when there is more light, not less. Also, the LDR analog input readings are very tiny ie between 0.0015 and 0.0025 when I print them on the screen. Could someone please show me an example of how I might multiply these readings so they are more user-friendly - or does it not really matter?
