(EDITED for clarity/typos)
It needed a few reboots & now it works. Bravo!
Using mv the_file loop_the_file created an extra ressource file under the old name in it's project folder, which was confusing Bela.
Maybe a missing flag missing ... I deleted those ressource files, and all works after reboot.
This feature makes a BIG difference for me for live use. I am very grateful for your support in this!
Refining the new state:
To prevent accidental firing in live use i'd propose for the button to only fire "next patch",
when it has been pressed for at least 1 second.
If so, then change the timing for the power down function to say 5 seconds.
This could also be achieved, if the button would only fire "next patch" OR "power down", when a second button is pressed at the same time, behaving like a shift button.
And question:
IF the above would work -> could one reactivate the now redefined "next patch" button to be used in PD or elsewhere for tap buttons, triggers and other short pressed uses (that possible at all?)?
Thank you for all you do!
    jayrope Apparently using mv the_file loop_the_file created an extra ressource file under the old name it's project folder, which was confusing Bela.
    how was it confusing it? Was it throwing an error of sorts? That file is actually always there, it is the binary that gets built and run, but it is normally hidden in the IDE. If you do "save as" from the IDE it will delete it for you.
    jayrope As a good precaution for accidental firing in live use i would propose for the button to only fire "next patch", when it has been pressed for at least 1 second
    good point. This requires another change in core/PRU.cpp: find the lines
                    if(++stopButtonCount > 10){
                        printf("Button pressed, quitting\n");
                        Bela_requestStop();
    just below your previous edit. You can then replace 10 with something like context->audioSampleRate / context->audioFrames * 1.0, where 1.0 is the number of seconds you want to wait before the button stops the current patch.
    and then additionally give the power down function a bigger delay of say 5 seconds
    to do this you need an extra parameter to bela-cape-btn in the bela_button.service file: --hold-press-timeout-ms 5000
    jayrope And question: IF the above would work could on reactivate the now redefined "next patch" to be used in PD or elsewhere for tap buttons, triggers and other short pressed uses (that possible at all?)?
    I think it should work.
    jayrope This could also be achieved for the button to only fire "next patch" OR "power down", when a second button is pressed at the same time, behaving like a shift button.
    This is more complicated, I was thinking that maybe what I need to add is a way for the Pd user to stop the program by sending a Pd message. Then it is up to your Pd patch to handle the logic for triggering that message (this can coexist with the other methods). All that should be needed to achieve this is adding this patch to core/default_libpd_render.cpp (untested):
    diff --git a/core/default_libpd_render.cpp b/core/default_libpd_render.cpp
    index bcec769c..443726cf 100644
    +++ b/core/default_libpd_render.cpp
    @@ -350,6 +350,11 @@ void Bela_listHook(const char *source, int argc, t_atom *argv)
     #endif // BELA_LIBPD_GUI
    +       if(strcmp(source, "bela_stop") == 0)
    +               Bela_requestStop();
    +               return;
      giuliomoro jayrope Apparently using mv the_file loop_the_file created an extra ressource file under the old name it's project folder, which was confusing Bela.
      I used mv, because i see no patch rename function in the IDE. Probably overlooked it.
      When the ressource files were visible, Bela simply hung during boot, there was a loop of two processes going on, but the log has been deleted already...
      anyhow deleting the visible ressource files from the project folders has solved this.
      Now trying your suggestions to change button timing, guessing though, that if(++stopButtonCount > 10){
      Bela_requestStop();
      just needs a higher number than 10?
        jayrope I used mv, because i see no patch rename function in the IDE. Probably overlooked it.
        there is no one as such - unfortunately - but there is a "save as".
        jayrope When the ressource files were visible, Bela simply hung during boot, there was a loop of two processes going on, but the log has been deleted already...
        weird one
        jayrope just needs a higher number than 10?
        This count is in blocks, so changing the blocksize will affect the number of blocks per second, so waiting 1000 blocks will take different amounts of time depending on blocksize. The way I suggested it you can enter the actual number of seconds you are interested in and it will be always the same time regardless of blocksize.
        Activating button after 1 sec works, thank you.
        I suppose i make a mistake regarding the timeout for shut down, my bela_button.service file looks like this
        Description=Monitor the Bela cape button
        After=networking-online.target
        [Service]
        Type=simple
        ExecStart=/usr/bin/stdbuf -oL -eL /usr/local/bin/bela-cape-btn --pressed 1 --pin 86 --hold /opt/Bela/bela_button_hold.sh --delay 20 --monitor-click 0
        Environment=HOME=/root
        --hold-press-timeout-ms 4000
        [Install]
        WantedBy=default.target
        what am i doing wrong?
        The --hold-press... part shouldn't be on a line of its own, it should be at the end of the line with bela-cape-btn
        So this should be right?
        [Service]
        Type=simple
        ExecStart=/usr/bin/stdbuf -oL -eL /usr/local/bin/bela-cape-btn --pressed 1 --pin 86 --hold-press-timeout-ms 4000 --hold /opt/Bela/bela_button_hold.sh --delay$
        you have --delay$ which should be --delay 20 --monitor-click 0
        In other words, the line should be:
        ExecStart=/usr/bin/stdbuf -oL -eL /usr/local/bin/bela-cape-btn --pressed 1 --pin 86 --hold-press-timeout-ms 4000 --hold /opt/Bela/bela_button_hold.sh --delay 20 --monitor-click 0
          giuliomoro The --delay$ was a copy error from my Terminal (OSX). It's been a few hours of back & forth, with things like pressing button for 1 sec, resulting in patch change ... but then an immediate shut down as well, although i surely hadn't pressed 4 secs for shutdown. There's been other weird things that i'll spare you from.
          Trying between standalone and IDE or just SSH connected modes also produce different results occasionally.
          Now it functions in standalone, but not the shutdown command. For me that's good, as i wouldn't need shutdown probably. Just trying to make sure my rack is fucntional for a concert on Saturday.
          Thank you again, and for now, this week I'll create no more troubles 🙂 Enjoy the weekend.
          a month later
          a year later
          OMG I fixed it. The SD card was falling out on the back! Due I think to hitting the USB cable upon installation to the rack - Whew!
