Hello there,
My SuperCollider code (using a bunch of Trill sensors) works fine, when I execute it. Now I am trying to run it on boot, but when I launch it on boot the TrillCentroids UGen cannot be found.
Nov 03 17:17:11 bela stdbuf[242]: ERROR: Class not defined.
Nov 03 17:17:11 bela stdbuf[242]: in interpreted text
Nov 03 17:17:11 bela stdbuf[242]: line 99 char 29:
Nov 03 17:17:11 bela stdbuf[242]: centroids = TrillCentroids.kr(i2c_bus, i2c_address, thresh, prescaler);
I have extended the waiting time after boot, but that doesn't work.
This is the SuperCollider code that I am running:
/* MULTIPLE SENSORS WITH TRILL HUB */
fork{
15.wait;
s = Server.default;
s.options.numAnalogInChannels = 8;
s.options.numAnalogOutChannels = 8;
s.options.blockSize = 16;
s.options.postln;
s.waitForBoot {
SynthDef(\ring, {|t_recalibrate=0.0|
var i2c_bus = 1;
var i2c_address = 0x38;
var thresh = 0.22;
var prescaler = 1;
var touchsigs = DC.ar(0).dup(3);
var centroids;
var out, ping;
//centroids = TrillCentroids.kr(i2c_bus, i2c_address, thresh, prescaler);
touchsigs[0] = Resonz.ar(WhiteNoise.ar(Lag.kr(centroids[1]* 5, 0.2) ),centroids[2].linexp(0.0, 10.0, 400, 8000), centroids[1].linexp(0.0, 1.0, 0.5, 0.01), 0.9);
centroids[2].poll;
touchsigs[1] = PMOsc.ar((centroids[3]+0.001) * 2500, 500, centroids[4].linexp(0.0, 2000, 0.1, 12.0), 0.1, mul: 0.5)
* EnvGen.ar(Env.perc, (centroids[4] > 0.0), timeScale: centroids[4].linexp(50, 500, 0.3, 5.0));
// touch3 another percussive plucky sound with pull-off behavior
touchsigs[2] = Resonz.ar(
Pluck.ar(PinkNoise.ar, (centroids[6] < 0.05), 0.2, centroids[5].linexp(0.0, 1.0, 80, 1000).reciprocal, 3, 0.5, mul: 6.0),
centroids[5].linexp(0.0, 1.0, 800, 2400), 0.1, 4.0).tanh;
//out = Splay.ar(touchsigs);
out = Mix(touchsigs);
SendReply.kr(Impulse.kr(8), "/ring", centroids);
ping = EnvGen.ar(Env.perc, t_recalibrate) * SinOsc.ar(440);
Out.ar(0, out!2 );
//Out.ar(0, ping);
}).add;
SynthDef(\square, {|t_recalibrate=0.0|
var i2c_bus = 1;
var i2c_address = 0x28;
var thresh = 0.22;
var prescaler = 1;
var centroids;
var out, ping;
touchsigs[0] = Pluck.ar(WhiteNoise.ar, (centroids[2] > 0 ), 0.2, centroids[1].linexp(0.0, 1.0, 70, 300).reciprocal, 5, 0.9);
SendReply.kr(Impulse.kr(8), "/square", centroids);
Out.ar(0, out!2 );
//Out.ar(0, ping);
}).add;
SynthDef(\flex, {|t_recalibrate=0.0|
var i2c_bus = 1;
var i2c_address = 0x48;
var thresh = 0.01;
var prescaler = 4;
var centroids;
var out, ping;
touchsigs[0] = CombC.ar( Pluck.ar(WhiteNoise.ar, (centroids[2] > 0 ), 0.2, centroids[1].linexp(0.0, 1.0, 70, 300).reciprocal, 5, 0.9), 0.5, centroids[1].linexp(0.0, 1.0, 0.01, 0.5), 3.0 );
SendReply.kr(Impulse.kr(8), "/flex", centroids);
Out.ar(0, out!2 );
//Out.ar(0, ping);
}).add;
s.sync;
~square_synth = Synth(\square);
~flex_synth = Synth(\flex);
~ring_synth = Synth(\ring);
//OSCFunc(\trill, {|msg| msg[3..].postln }, "/trill");
// Illustrates how to recalibrate the Trill sensor's baseline value if the touchpad configuration changes
// loop {
// 55.wait;
// "Reset baseline in 5s...".postln;
// 5.wait;
// "Baseline reset!".postln;
// ~tr.set(\t_recalibrate, 1);
// }.fork;
And there's a small CPP file to add the Trill library:
/***** SC_libs.cpp *****/
Do I need to add the Trill UGens in some kind of special way, when launching on boot?
Kind regards,
Sjoerd
