So it seems that this driver does not work with v0.3.8. I tried the following procedure:
root@bela:~/rtl8812AU_8821AU_linux# git checkout 4d1726146fd96552c9fa5af05c75187027d6885b
Note: checking out '4d1726146fd96552c9fa5af05c75187027d6885b'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
git checkout -b <new-branch-name>
HEAD is now at 4d17261... Add USB Device T4U AC1300 with 2357:0115 (#274)
root@bela:~/rtl8812AU_8821AU_linux# make ARCH=arm && make ARCH=arm install
I'm not too sure if it specifically installed that version but I'm assuming it did based on the fact it mentions that the HEAD is now at that version. The driver proceeds to install and after reboot. I tried the following to check:
root@bela:~# lsusb
Bus 001 Device 007: ID 0781:5571 SanDisk Corp. Cruzer Fit
Bus 001 Device 006: ID 0846:9052 NetGear, Inc. A6100 AC600 DB Wireless Adapter [Realtek RTL8811AU]
Bus 001 Device 005: ID 2109:2813 VIA Labs, Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
root@bela:~# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
link/ether a8:10:87:c2:4c:54 brd ff:ff:ff:ff:ff:ff
4: usb0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:87:c2:4c:56 brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:87ff:fec2:4c56/64 scope link
5: usb1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether be:1a:87:c2:4c:59 brd ff:ff:ff:ff:ff:ff
inet6 fe80::bc1a:87ff:fec2:4c59/64 scope link
6: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 38:94:ed:bd:cd:1c brd ff:ff:ff:ff:ff:ff
inet 192.168.30.1/24 brd 192.168.30.255 scope global wlan0
inet6 fe80::3a94:edff:febd:cd1c/64 scope link
root@bela:~# ifdown wlan0; ifup wlan0 --verbose
ifup: configuring interface wlan0=wlan0 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/hostapd
hostapd: /usr/sbin/hostapd -B -P /run/hostapd.wlan0.pid /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
/bin/ip addr add 192.168.30.1/255.255.255.0 broadcast 192.168.30.255 dev wlan0 label wlan0
/bin/ip link set dev wlan0 up
/bin/run-parts --exit-on-error --verbose /etc/network/if-up.d
run-parts: executing /etc/network/if-up.d/avahi-daemon
run-parts: executing /etc/network/if-up.d/openssh-server
run-parts: executing /etc/network/if-up.d/upstart
run-parts: executing /etc/network/if-up.d/wpasupplicant
root@bela:~#
Upon using the final command ifdown wlan0; ifup wlan0 --verbose the network shows up to connect to from the laptop but unfortunately fails to connect or assign the address for the laptop which would be 192.168.30.2 in this case.
