Hello there,
For a project I am working with the Bela mini capelet in conjunction with Trill sensors. I am using SuperCollider and found the TrillCentroids and TrillRaw UGens on the github of Jonathan Reus - and this works great with the TrillSquare, TrillBar etcetera.
Right now I am trying to figure out how I can get the readings from the TrillFlex into SuperCollider. When I run the flex-default and flex-visual examples, everything works smoothly.
But when I run my SuperCollider code, I get a:
Unable to identify device
ERROR: Unable to initialize touch sensor```
Is it possible to use the Flex with the TrillCenroids or TrillRaw UGen?
And if yes, am I doing something silly?
I know that the i2c address of the flex is 0x48.
This is my SuperCollider code:
s = Server.default;
s.options.numAnalogInChannels = 8;
s.options.numAnalogOutChannels = 8;
s.options.blockSize = 16;
s.options.postln;
s.waitForBoot {
SynthDef(\sketch, {|t_recalibrate=0.0|
var i2c_bus = 1;
var i2c_address = 0x48;
var thresh = 0.22;
var prescaler = 1;
var touchsigs = DC.ar(0).dup(3);
var centroids;
var out, ping;
centroids = TrillCentroids.kr(i2c_bus, i2c_address, thresh, prescaler);
touchsigs[0] = CombC.ar( Pluck.ar(WhiteNoise.ar, (centroids[2] > 0 ), 0.2, centroids[1].linexp(0.0, 1.0, 70, 300).reciprocal, 5, 0.9), 0.5, centroids[1].linexp(0.0, 1.0, 0.01, 0.5), 3.0 );
touchsigs[1] = PMOsc.ar((centroids[3]+0.001) * 2500, 500, centroids[4].linexp(0.0, 2000, 0.1, 12.0), 0.1, mul: 0.5)
* EnvGen.ar(Env.perc, (centroids[4] > 0.0), timeScale: centroids[4].linexp(50, 500, 0.3, 5.0));
// touch3 another percussive plucky sound with pull-off behavior
touchsigs[2] = Resonz.ar(
Pluck.ar(PinkNoise.ar, (centroids[6] < 0.05), 0.2, centroids[5].linexp(0.0, 1.0, 80, 1000).reciprocal, 3, 0.5, mul: 6.0),
centroids[5].linexp(0.0, 1.0, 800, 2400), 0.1, 4.0).tanh;
out = Splay.ar(touchsigs);
SendReply.kr(Impulse.kr(8), "/trillcentroiddata", centroids);
ping = EnvGen.ar(Env.perc, t_recalibrate) * SinOsc.ar(440);
Out.ar(0, out );
//Out.ar(0, ping);
}).add;
s.sync;
~tr = Synth(\sketch);
OSCFunc(\trill, {|msg| msg[3..].postln }, "/trill");
// Illustrates how to recalibrate the Trill sensor's baseline value if the touchpad configuration changes
loop {
55.wait;
"Reset baseline in 5s...".postln;
5.wait;
"Baseline reset!".postln;
~tr.set(\t_recalibrate, 1);
}.fork;
Any advice very much appreciated.
All the best,
Sjoerd
