giuliomoro I successfully updated to v0.3.8b - I redid all the steps outlined in the "Using Bela as a wi-fi hotspot" documentation and received the below output. But I'm not seeing the network when trying to connect to Bela with my laptop. Any ideas?
root@bela:~# ifdown wlan0; ifup wlan0 --verbose
ifup: configuring interface wlan0=wlan0 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/hostapd
hostapd: /usr/sbin/hostapd -B -P /run/hostapd.wlan0.pid /etc/hostapd/hostapd.conf
Configuration file: /etc/hostapd/hostapd.conf
wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
wpa_supplicant: wpa-driver nl80211,wext (default)
wpa_supplicant: /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf -C /run/wpa_supplicant
Starting /sbin/wpa_supplicant...
wpa_supplicant: waiting for "/run/wpa_supplicant.wlan0.pid": 0 (max. 5)
wpa_supplicant: creating sendsigs omission pidfile: /run/sendsigs.omit.d/wpasupplicant.wpa_supplicant.wlan0.pid
wpa_supplicant: ctrl_interface socket located at /run/wpa_supplicant/wlan0
/bin/ip addr add 192.168.30.1/255.255.255.0 broadcast 192.168.30.255 dev wlan0 label wlan0
/bin/ip link set dev wlan0 up
/bin/run-parts --exit-on-error --verbose /etc/network/if-up.d
run-parts: executing /etc/network/if-up.d/avahi-daemon
run-parts: executing /etc/network/if-up.d/openssh-server
run-parts: executing /etc/network/if-up.d/upstart
run-parts: executing /etc/network/if-up.d/wpasupplicant
