Hi All,
Tried battery powering a bela mini via 5v battery out to Bela bat+, battery- to Bela gnd and running a momentary switch between gnd and pb. The board worked fine for about 15 minutes but now appears completely dead.
no flashy lights when connected via battery
no lights/communication when plugged into computer
In troubleshooting section of the wiki it says to disconnect everything and look for connections to ground which has been done. I've checked continuity between ground and all of the other pins and did not find anything.
What are the best recommended next steps for troubleshooting?
Regards,
Zeke Norris
