silver2row
The vocoder has the best instructions. If you make the connections as diagrammed on the github README.md then the vocoder will work. You will need a microphone preamp for the ADC CH1 connection
https://github.com/transmogrifox/Bela_Misc/tree/master/vocoder
The "klingon tone" will also work without external connections because the defaults are set to something that will change the sound, and quick review of the code shows it starts in an active state:
https://github.com/transmogrifox/Bela_Misc/tree/master/klingon_tone
You can do more with knobs connected, but it will do something audibly different without.
The sample/hold modulator, ADSR and state variable filter require more understanding of Bela and the code. The TransmogriFX repo ( https://github.com/transmogrifox/transmogriFX_bela/tree/master/src ) works as a complete system but it requires a combination of correct hardware connections and an understanding of what the hardware inputs do in the code -- neither of which are documented yet, so you have to study the code and experiment to figure out my particular way of doing things to make it work.
