Tractor That is absolutely terrifying. How did you even spot that??
I knew the code was running before I pasted it into the gist and stopped working when I copied it out, so it must have been something stupid! Also, it's always the first error the one that could be causing all the others, so the first error in the console:
unexpected unqualified-id column: 1, line: 1
indicated something wrong on line 1.
Tractor At some point I do plan on using more than one of these Evos simultaneously. I will revert to you, if you're willing. Meanwhile - with your skills at coding in the blind - it's nice to count another device testing as extant in the Bela firmament.
In that case, following the blueprint of the TRILL changes may be more appropriate, as it deals with bidirectional communication, so you can set the bus, address and an ID from Pd and then use the ID to refer to the device later on.
