not quite there yet. jeeesus h christ.
i got rid of a lot of noise by moving the fan for the ATX from the 12v line (on PWM) to the 5v line, which i'm not using.
only noise i hear now, changes with the content of the display 😠
when the display is black (aka not showing anything), there's hardly any noise.
when i display letters or numbers, i get noise. noise varies, i'm guessing with the number of active pixels.
weird thing is: when i unplug the cable from bela to the amp on Bela's side, it's dead quiet.
i would expect a loudish hum from a cable hanging loose, but no.
i could try to work out where the display noise is coming from, but i'm getting quite fed up with the whole thing TBH. if it's quiet when unplugged and the noise is masked when playing audio, i'm thinking of switching the audio lines. should prevent the pop as well.
sigh. not the easiest project, this one.
is there an analog gnd/ digital gnd separation on Bela i'm overlooking?
the display noise might actually be creeping through the ground portion of my BS170/relay setup.
the relay is supposed to be completely separated, but i do have a common ground point on P9.1.
