Hello,
it erased my little webpage
that's expected, the update script currently replaces all the following files/folders:
core include Makefile lib examples Doxyfile IDE
in fact, an "advanced user" placing/editing files there is supposed to know this. A warning pops up when you do the update but we may want to make it more clear.
This updated version of libpd does not require the [metro]--[bang], it will automatically send a message to its output when a new input comes in.
The default_libpd_render.cpp and libpd are automatically updated.
default_libpd_render.cpp is used as the default wrapper around your Pd patch when using libpd. You don't have to know about it unless you want to change something about it (e.g.: for a custom application). In that case, you'd use it as a template to craft your own. I mentioned it here because in case you had your own custom rende.cpp, then in order to get [netreceive] to work, you would have needed to apply to your file those changes I applied to the default one. But it seems like you don't need to worry.
Try with
[netreceive -u -b 7562]
[print]
and see if anything gets printed to the console.
If it does, and it looks too much like gibberish, then nexusUI (which I know nothing about) may not be sending binary but plain text, so try removing the -b (which stands for "binary").
