My bela mini, which is a replacement for my first mini, seems to be having issues. It was occasionally disconnecting from USB. I reboot the device and then I can connect again. But today it had to reboot it many times, and it did resolve the issue. Finally I removed my cape and reset a few times and finally is started working again.
I'm going to remove the need for my cape and put in a breadboard instead, but I'm fearing that this problem will reoccur and potentially be permanent again. In fact I just bought another mini so I would have a backup. To add to that I accidently deattached the USB micro connected from the beagle board. It still seems to work, but not sure I can re-secure it.
Thoughts on whether this bela mini board is going to continue having problems?
Thanks, Paul
