Hey guys,
I am getting an error on my bela when I try to change the code, I get this message if I try to build and run:
compiling class library...
Found 704 primitives.
Compiling directory '/usr/local/share/SuperCollider/SCClassLibrary'
Compiling directory '/usr/local/share/SuperCollider/Extensions'
Compiling directory '/root/.local/share/SuperCollider/Extensions'
numentries = 1092747 / 12234200 = 0.089
4150 method selectors, 2948 classes
method table size 8110832 bytes, big table size 48936800
Number of Symbols 11686
Byte Code Size 329951
compiled 447 files in 3.91 seconds
Info: 4 methods are currently overwritten by extensions. To see which, execute:
MethodOverride.printAll
compile done
localhost : setting clientID to 0.
internal : setting clientID to 0.
Class tree inited in 0.15 seconds
Welcome to SuperCollider 3.10.0-beta1. For help type ctrl-c ctrl-h (Emacs) or :SChelp (vim) or ctrl-U (sced/gedit).
Booting server 'localhost' on address 127.0.0.1:57110.
Faust: supercollider.cpp: sc_api_version = 3
Faust: FaustGreyholeRaw numControls=7
Faust: FaustJPverbRaw numControls=11
Found 0 LADSPA plugins
Server 'localhost' exited with exit code 0.
When I plugg it off and on again, the bela works completely fine but after a couple of minutes the usb connection is lose.
What is happening? Any ideas or experiences with it?
