yannseznec Hi! I'm running into an issue where my USB MIDI device will not connect to the Bela when I'm running a project from boot. Here are the symptoms: I have a Pd patch that uses [ctlout] to send messages to a Teensy running as a USB MIDI controller. I use one message to turn on the LED on the Teensy so I know that it has connected properly. I also have a tone playing in the patch to make sure that the patch is launching properly too. If I run the patch from the IDE on the Bela it connects perfectly and sends the messages to the Teensy. The light turns on, everything is great. If I set the patch to run on boot, the MIDI connection is never made. I know the patch launches properly on the Bela, because the test tone starts playing. However the Teensy light does not turn on, implying that it is not receiving MIDI messages. This can be confirmed by launching the IDE when the patch has been set to launch on boot. In the console window it says: bela stdbuf[93]: No MIDI device enabled At that point, if I stop the Bela and then click Build & Run the patch launches perfectly again, the MIDI connection is made, and the console window lists a MIDI device as enabled. I have definitely used this approach in the past, so I'm confused!
yannseznec Oh I just found this post on the forums from a few days ago, my apologies https://forum.bela.io/d/1493-help-problem-receiving-midi-in-run-on-boot-mode I tried the fix there and it seems to have worked right away. Thanks!
giuliomoro New image out that fixes it https://github.com/BelaPlatform/bela-image-builder/releases/ (v0.3.8b and above)
