Help: Problem receiving midi in Run on boot mode
no, it's done once for all: it's a system-level change.
New image out that fixes this issue https://github.com/BelaPlatform/bela-image-builder/releases/ (v0.3.8b and above)
I reflashed my bela to this new image but now I don't get any midi input even on the IDE...by default it says No MIDI device enabled...Any ideas off the top of your head?
Thanks,
Tom
tkay I reflashed my bela to this new image but now I don't get any midi input even on the IDE...by default it says No MIDI device enabled...Any ideas off the top of your head?
Does this happen only when running the project at boot or also during regular operation?
Can you run amidi -l
in the console at the bottom of the IDE and report its result?
it doesn't receive any midi either on boot or on the ide
so the device is not showing up (hw:0,0
is the virtual interface over USB between Bela and yout computer)
What about lsusb -l
What MIDI device is connected? Does it require external power? Does it have any LEDs on it showing that it's receiving power?
Its a cheap usb powered keyboard...But it worked fine before. I also tried a powered nord keyboard and same thing happened...
it does have LED and it shows as being powered
it says invalid option ...if I use the v function it says this:
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9 Hub
bInterfaceSubClass 0 Unused
bInterfaceProtocol 0 Full speed (or root) hub
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0004 1x 4 bytes
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
wHubCharacteristic 0x0011
Per-port power switching
No overcurrent protection
TT think time 8 FS bits
bPwrOn2PwrGood 5 * 2 milli seconds
bHubContrCurrent 0 milli Ampere
DeviceRemovable 0x02
PortPwrCtrlMask 0xff
Hub Port Status:
Port 1: 0000.010c power oc suspend
Device Status: 0x0001
Self Powered
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9 Hub
bDeviceSubClass 0 Unused
bDeviceProtocol 1 Single TT
bMaxPacketSize0 64
idVendor 0x1d6b Linux Foundation
idProduct 0x0002 2.0 root hub
bcdDevice 4.14
iManufacturer 3 Linux 4.14.108-ti-xenomai-r135 musb-hcd
iProduct 2 MUSB HDRC host driver
iSerial 1 musb-hdrc.0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 0mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 12
Hub Descriptor:
bLength 9
bDescriptorType 41
nNbrPorts 1
Hub Port Status:
Port 1: 0000.0
tkay it says invalid option ...if I use the v function it says this:
sorry it would have been just lsusb
(without options), could you please try again?
Can you also show the output of:
lsmod
Then:
- unplug the MIDI device
- wait 5 seconds
- plug in the MIDI device
- run dmesg | tail -n 20
and show the output of this command
In all this, can you try a different USB cable for the device and verify whether that is the issue? Some cables only carry power and not carry data. Some socket connectors may also prevent the plug from being fully inserted, obtaining a similar result (only power, no data) [which is - by the way - what happened to me a minute ago].
Thanks for such quick responses
lsubs threw this at me:
root@bela ~/Bela# lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
lsmod said this:
root@bela ~/Bela# lsmod
Module Size Used by
ti_am335x_adc 16384 0
kfifo_buf 16384 1 ti_am335x_adc
industrialio 73728 2 ti_am335x_adc,kfifo_buf
usb_f_midi 20480 2
usb_f_acm 16384 2
u_serial 20480 3 usb_f_acm
usb_f_mass_storage 53248 2
usb_f_ncm 28672 2
usb_f_rndis 32768 2
u_ether 20480 2 usb_f_ncm,usb_f_rndis
omap_rng 16384 0
rng_core 16384 1 omap_rng
pwm_tiehrpwm 16384 0
c_can_platform 16384 0
c_can 20480 1 c_can_platform
can_dev 28672 1 c_can
spidev 20480 0
evdev 24576 1
ti_am335x_tscadc 16384 1 ti_am335x_adc
uio_pdrv_genirq 16384 0
spi_gpio 16384 0
spi_bitbang 16384 1 spi_gpio
snd_usb_audio 184320 0
snd_hwdep 16384 1 snd_usb_audio
snd_usbmidi_lib 32768 1 snd_usb_audio
snd_rawmidi 32768 2 snd_usbmidi_lib,usb_f_midi
snd_seq_device 16384 1 snd_rawmidi
rtdm_pruss_irq 16384 0
libcomposite 65536 16 usb_f_acm,usb_f_ncm,usb_f_mass_storage,usb_f_rndis,usb_f_midi
ip_tables 24576 0
x_tables 32768 1 ip_tables
root@bela ~/Bela#
and after unpluging and pluging the keyboard and running dmesg | tail -n 20 it said this:
[ 18.363011] LUN: removable file: (no medium)
[ 23.476378] ti_am3359-tscadc 44e0d000.tscadc: chan 0 step_avg truncating to 16
[ 23.476400] ti_am3359-tscadc 44e0d000.tscadc: chan 1 step_avg truncating to 16
[ 23.476409] ti_am3359-tscadc 44e0d000.tscadc: chan 2 step_avg truncating to 16
[ 23.476418] ti_am3359-tscadc 44e0d000.tscadc: chan 3 step_avg truncating to 16
[ 23.476427] ti_am3359-tscadc 44e0d000.tscadc: chan 4 step_avg truncating to 16
[ 23.476436] ti_am3359-tscadc 44e0d000.tscadc: chan 5 step_avg truncating to 16
[ 23.476445] ti_am3359-tscadc 44e0d000.tscadc: chan 6 step_avg truncating to 16
[ 23.476454] ti_am3359-tscadc 44e0d000.tscadc: chan 7 step_avg truncating to 16
[ 24.472524] usb0: HOST MAC be:1a:05:fb:7d:b9
[ 24.492209] usb0: MAC be:1a:05:fb:7d:ba
[ 24.504087] usb1: HOST MAC be:1a:05:fb:7d:bc
[ 24.504457] usb1: MAC be:1a:05:fb:7d:bd
[ 27.485059] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 28.518448] IPv6: ADDRCONF(NETDEV_UP): usb1: link is not ready
[ 28.700546] configfs-gadget gadget: high-speed config #1: c
[ 28.701482] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready
[ 31.008798] IPv6: ADDRCONF(NETDEV_CHANGE): usb1: link becomes ready
[ 308.926109] rtdm_pruss_irq_close
[ 312.528881] rtdm_pruss_irq_open
root@bela ~/Bela#
I also tried 2 different cables
really weird ... can you try the Nord keyboard again and lsusb
and amidi -l
ok will do and report back tomorrow, have to leave the studio now...I should mention that I also ran the first script that you gave me before the new image came out...
So I plugged in the same keyboard today and magically it worked...I guess it must be a loose connection on the usb?
It could be ... it's a mystery! Maybe check the inside of the USB socket (and plug) for any detritus? although that'd have to be pretty big to cause electrical continuity issues!
I will add to this that I frequently have the USB MIDI fail to work on boot up, maybe one time out of ten, randomly it seems.
