From the latest 6.15 build, the STK opcodes are still missing.
- here is the output of the console, followed by a test instrument for you.
- the test instrument does work in CsoundQt on the Mac and on the Terminal with the latest developer build.
=====. Console ====
Building project ...
Build finished
Running project ...
0dBFS level = 32768.0
--Csound version 6.15 (float samples) Nov 1 2020
[commit: 82b3e0fa820b12c6980de82e96d49d373b29f339]
libsndfile-1.0.27
Device type: Bar (1)
Address: 0x20
Firmware version: 2
Device type: Square (2)
Address: 0x28
Firmware version: 2
Device type: Ring (4)
Address: 0x38
Firmware version: 2
Device type: Hex (5)
Address: 0x40
Firmware version: 2
realtime mode enabled
UnifiedCSD: /root/Bela/projects/Aug2/NL-STKBowedRCB.csd
STARTING FILE
Creating options
Creating orchestra
closing tag
Creating score
rtmidi: ALSA Raw MIDI module enabled
error: syntax error, unexpected T_IDENT (token "STKBowed") from file /root/Bela/projects/Aug2/NL-STKBowedRCB.csd (1)
line 19:
asig STKBowed <<<
Unexpected untyped word asig when expecting a variable
Parsing failed due to invalid input!
Stopping on parser failure[m
[msorting score ...
... done
setting dummy interface
displays suppressed
orch now loaded
SECTION 1:
Initialising spinlock...
Starting realtime mode queue: 0xb515b010 thread: 0x340a98
Error: Csound's ksmps (10) and Bela's periodSize (16) differ and the latter is not a multiple of the former. This would lead to uneven CPU usage, and result in dropouts while some CPU resources remain unused.
error initialising Bela
inactive allocs returned to freespace
end of score. overall amps: 0.0
overall samples out of range: 0
0 errors in performance
backtrace() returned 0 addresses
Csound tidy up: Segmentation fault
make: *** [runide] Error 1
Bela stopped
root@bela ~/Bela#
===== STKBowed.csd =====
<CsoundSynthesizer>
<CsOptions>
--daemon -dm0
</CsOptions>
<CsInstruments>
sr = 44100
ksmps = 16
nchnls = 2
0dbfs = 1
instr 1
ipch = p4
kv2	=  p7				; position on bow
kv1	line p5, p3, p6		; bow pressure
kv4	line 0, p3, 7		        ; depth of low-frequency oscillator
asig STKBowed cpspch(ipch), 1, 2, kv1, 4, kv2, 11, 40, 1, kv4, 128, 100
	outs	asig, asig
endin
</CsInstruments>
<CsScore>
i 1  0 15  6.00 20 100 115
i 1 17  3  7.00 120 10   0
i 1 21  3  7.09 20  40  30
i 1 25 12  7.03 60  1   60
e
</CsScore>
</CsoundSynthesizer>
    csounder From the latest 6.15 build, the STK opcodes are still missing.
    Yes, they will be added at some point in the near future, once everything else is sorted and we are closer to making a new release. Thanks for the example code, I will use it to test them when I add them in.
    @csounder could you please help @basswoman here ?
      giuliomoro Yes. I have been working with @basswoman and we have been making progress. I am looking now for specific models that I can share with her and that will be a part of the set that I deliver to you ultimately.
      11 days later
      Thank you so much guys! I think I got it. Now I'm trying to figure out how to make my 9 buttons to send midi note messages so I can play the tuning scale form "ftgen".
