Remork - this might be a total noob issue, but i can't seem to find info on what Pd release Bela is running.
when you start a patch it tells you the version. It should be 0.48 on most boards out there
Remork the latest stable release is 0.51-1, but how would i go about upgrading to that on Bela (if that is not what is running already), or is this not recommended?
You have to wait for me to finish the port. It's kind of working, I just need some time to work on it 😛 It's in my short-term priority list.
out of curiosity, what are you looking for in more recent versions?
    giuliomoro out of curiosity, what are you looking for in more recent versions?
    nothing in particular, really. as i said, just looking for optimum compatability.
    the unlimited undo/redo is a big plus when editing (introduced in 0.49), but since editing isn't happening on Bela itself that's a bit of a non-issue. not as long as 0.48 can open my 0.49 patches.
    although i can imagine something like [savestate] (also 0.49) might be nice to have.
    3 years later
    Reviving this old thread as I'm trying to use [pdcontrol] and [slop~] which are not part of Pd-0.48-2, which is the Pd version my Bela comes with. Has Pd been updated? Am I running an old image (it's quite some when I last tried to use my Bela)?
    How can I update?
    It's funny that when I SSH into the Bela, I can't find any Pd executable. I know it's working with LibPd, but I thought that Pd would be there.
    Any hints are welcome.
    giuliomoro I just did an update on my Bela, but I'm still getting 0-48-2. I updated my Bela from the IDE. Is there something I need to do in the terminal as well?
    can you show the content of the "version details" dialog, accessible via the the "other system functions" section of the IDE preferences?
      giuliomoro Hm, there's doesn't seem to be such an option in "other system functions". Perhaps the IDE needs an update as well? Is there something I can do in the terminal?
      Then I guess the update didn't go well , as the IDE should have been updated, too, as part of the procedure. Can you retry the update and report here any messages that are produced in the process?
      giuliomoro I tried to update the board with the script, and this is the output:
      DATE=2023-12-17T13:40:41Z
      FILENAME=Bela-master
      METHOD=update_board
      Checking the board is up and running at root@192.168.7.2...Warning: Permanently added '192.168.7.2' (ED25519) to the list of known hosts.
      done
      Board found at root@192.168.7.2
      Updating the Bela core code in root@192.168.7.2:/root/Bela
      All the changes to the CORE files in the remote folder /root/Bela will be LOST. The content of these files/folders will be lost:
        core include Makefile Makefile.libraries Makefile.linkbela examples Doxyfile scripts resources pru libraries
      Your projects stored in /root/Bela/projects should be safe (and surely you have already backed them up somewhere safe, haven't you?).
      Are you sure you want to continue? (y/N) y
      Updating Bela core files to remote folder /root/Bela
      Stopping Bela...done
      Updating files...done
      Scope
      Using library Scope
      Using library WSServer
      Using library ne10
      Midi
      Using library Midi
      Gui
      Using library Gui
      Trill
      Using library Trill
      Pipe
      Using library Pipe
      make: Entering directory '/root/Bela/resources/tools/bela-cape-btn'
      gcc bela-cape-btn.c -o bela-cape-btn
      bela-cape-btn.c: In function 'run':
      bela-cape-btn.c:420:22: error: 'pfd' undeclared (first use in this function)
          int result = poll(pfd, 1, pollTime);
      bela-cape-btn.c:420:22: note: each undeclared identifier is reported only once for each function it appears in
      Makefile:26: recipe for target 'bela-cape-btn' failed
      make: *** [bela-cape-btn] Error 1
      make: Leaving directory '/root/Bela/resources/tools/bela-cape-btn'
      An error occurred.
      Then I updated the IDE with the script and it worked fine. Version details gives me this:
      Image:
      Unknown
      Core code:
      Last attempted update on '17 Dec 2023 15:32:18 '
      via 'make update (legacy)'
      Git desc: '60b39c7-dirty'
      Trying to update the board through the IDE now fails with this:
      Upload completed, saving update file...
      unzipping and validating update...
      Validating archive...
      uncompressed size: 109452571
      Unzipping archive...
      Validating unzipped archive...
      ...done
      Applying update...
      No process to kill
      Copying /root/Bela to /tmp/belaPatch ...
      Applying patch in /tmp/belaPatch...
      Makefile:760: recipe for target 'update' failed
      make: *** [update] Error 1
      Error updating the board: `Error: make update failed with code 2`. Please try a different zip archive
      giuliomoro I flashed the Bela image to an SD card (Balena Etcher kept on failing and I had to do it from the terminal, on an 8 GB SD), and following the instructions here (https://learn.bela.io/using-bela/bela-techniques/managing-your-sd-card/#flash-an-sd-card-using-balena-etcher) I booted the board from the SD card using jumper wires, and it booted fine. What's next though? I updated Bela from the IDE, but I think the image was updated on the SD card instead of the on-board eMMC, is that correct?
      When I booted again without the SD card, I got the following, when trying to build my project:
      Building FormatConvert.S...
       ...done
      Building OscillatorBank_routines.S...
       ...done
      Building math_runfast.c...
       ...done
      Building I2c_Codec.cpp...
      Building project ...
       ...done
      Building BelaContextFifo.cpp...
       ...done
      Building Mmap.cpp...
       ...done
      Building RTAudio.cpp...
       ...done
       ...done
      Building Tlv320_Es9080_Codec.cpp...
       ...done
       ...done
      Building pru/pru_rtaudio.p...
       ...done
      Building pru/pru_rtaudio_irq.p...
       ...done
       ...done
      Building PruBinary.cpp...
       ...done
      Building RTAudioCommandLine.cpp...
      mv:
      cannot stat 'pru_rtaudio_irq_bin.h': No such file or directory
      make: *** [build/pru/pru_rtaudio_irq_bin.h] Error 1
      Makefile:501: recipe for target 'build/pru/pru_rtaudio_irq_bin.h' failed
      error setting project to run on boot!
       ...done
      Building Mcasp.cpp...
       ...done
      Building AuxTaskNonRT.cpp...
       ...done
      Building JSONValue.cpp...
       ...done
      Building board_detect.cpp...
       ...done
      Building AuxiliaryTasks.cpp...
       ...done
      Building PRU.cpp...
       ...done
      Building DataFifo.cpp...
       ...done
      Building AuxTaskRT.cpp...
       ...done
      Building I2c_MultiI2sCodec.cpp...
       ...done
      Building GPIOcontrol.cpp...
       ...done
      Building I2c_MultiTLVCodec.cpp...
       ...done
      Building PruManager.cpp...
       ...done
      Building MiscUtilities.cpp...
       ...done
      Building I2c_MultiTdmCodec.cpp...
       ...done
      Building Spi_Codec.cpp...
       ...done
      Building Gpio.cpp...
       ...done
      Building Es9080_Codec.cpp...
       ...done
      Building BelaContextSplitter.cpp...
       ...done
      Building DigitalChannelManager.cpp...
       ...done
      Building IirFilter.cpp...
       ...done
      Building JSON.cpp...
       ...done
      Building default_main.cpp...
       ...done
      Building default_libpd_render.cpp...
      Makefile:475: recipe for target 'build/core/default_libpd_render.o' failed
      Build finished
      In file core/default_libpd_render.cpp: no matching function for call to 'sys_doio' column: 7, line: 798
      core/default_libpd_render.cpp:798:7: error: no matching function for call to 'sys_doio'
                      if(!sys_doio(pd_this))
      /usr/local/include/libpd/s_stuff.h:168:6: note: candidate function not viable: requires 0 arguments, but 1 was provided
      void sys_doio();
      1 error generated.
      make: *** [build/core/default_libpd_render.o] Error 1
      How do I update to the latest master with the SD card? Or should I always boot from the SD card? I'd rather not, if it's possible.
      Once you boot your board with jumper wires, follow the instructions in "Flashing the eMMC" here to flash the emmc.
