giuliomoro yes i am using all code from the better-I2c branch; (libpd_default_render.cpp , i2C.cpp , i2c.h , i2cRt.ccp i2cRt.h , ringbuffer.c and ringbuffer.h) I just merged it with another project, and it's working fine.
giuliomoro now everything works, I want to compile this project with hvcc; it compiled succesfully, but i don't receive messages from the slave device anymore, also it doesn't send the messages to the slave device. I am using the render.cpp from/better-i2c/scripts/hvresources/render.cpp . in the 'libpd version' i am sending a couple of messages from my pd patch to the receiver "bela_i2c" , and am receiving messages in pd with a receive object "bela_i2c_in". they are defined in the default_libpd_render.cpp from the better-i2c branch. (but i can't find any reference to these in the heavy version of the render.cpp ).. only thing i found is : // unlike libpd, no need here to bind the bela_digitalOut.. receivers
// but make sure you do something like [send receiverName @hv_param]
// when you want to send a message from Heavy to the wrapper.
I figured i probably have to do something with this, but C++ is new to me. i'm able to understand code, and alter it a bit to do what i want, but if i'm writing /adding new code myself I don't know excactly what I am doing. Could you help me put this in the heavy version of the render.cpp?
getting there ... I rebased that branch on top of the current dev (here), and everything seems to be working ok, although it surely could be optimized a bit. Next step: heavy!
giuliomoro the compiler seems to have trouble with finding the "I2cRt.h" file . echo 'Building render.cpp...'
g++ -I/root/Bela/projects/CapSens_HEAVY_2 -I./include/legacy -I./include -I./build/pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a -mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ -D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtune=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -DBELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/CapSens_HEAVY_2/build/render.d" -o "/root/Bela/projects/CapSens_HEAVY_2/build/render.o" "/root/Bela/projects/CapSens_HEAVY_2/render.cpp"
/root/Bela/projects/CapSens_HEAVY_2/render.cpp:45:19: fatal error: I2cRt.h: No such file or directory
#include <I2cRt.h>
compilation terminated.
Makefile:459: recipe for target '/root/Bela/projects/CapSens_HEAVY/build/render.o' failed
make: *** [/root/Bela/projects/CapSens_HEAVY/build/render.o] Error 1
I tried compiling two different projects: one with files from the old better-i2c branch; (the libpd version builds and works fine) and the other one is the same project but with all files updated to those of the rebased better-i2c branch. they gave me excactly the same results.
also, you might want to know: when i updated the default_libpd_render.cpp file to the rebased one, it gave me some errors:
no matching member function for call to 'sendBuffer' column: 8, line: 202 and
no matching member function for call to 'sendBuffer' column: 10, line: 214
./libraries/Gui/Gui.h:128:10: note: candidate function template not viable: requires 2 arguments, but 3 were provided
int Gui::sendBuffer(unsigned int bufferId, std::vector<T,A> & buffer)
./libraries/Gui/Gui.h:135:10: note: candidate function template not viable: requires 2 arguments, but 3 were provided
int Gui::sendBuffer(unsigned int bufferId, T (&buffer)[N])
./libraries/Gui/Gui.h:142:10: note: candidate function template not viable: requires 2 arguments, but 3 were provided
int Gui::sendBuffer(unsigned int bufferId, T value)
/root/Bela/projects/I2c_Rebase/render.cpp:214:10: error: no matching member function for call to 'sendBuffer'
gui.sendBuffer(bufNum, s, strlen(s));
. because it said: requires 2 arguments but 3 were provided, i removed the second argument in the corresponding functions: removed "buf"in gui.sendBuffer(bufNum, buf, argc - 1); (line 202) and "s" in gui.sendBuffer(bufNum, s, strlen(s)); (line 214) Again, i do not know excactly what this is doing; but only after removing these arguments the project built and the libpd version worked with no problems.
It seems like you are just copying files in from one branch to another. That is a recipe for disaster, as you find yourself in a situation where a file (e.g.: core/default_libpd_render.cpp) relies on the version of libraries/Gui/Gui.h that is available on both the dev and better-i2c-rebased branches. Similarly, the render.cpp file for heavy that you are using relies on I2cRt.h to be present in the include/ folder, as it is in the better-i2c-rebased branch. To try out a branch properly, you have to update all the codebase at the same time. This procedure is explained here.
    giuliomoro Thanks, that did the job! i feel a bit stupid for not reading that myself to begin with 😛 the project now compiled to heavy succesfully; only one problem left; I think the Trill library isn't working correctly on this branch : the other project that i wanted to merge it with now doesn't want to build anymore, I get the error: In file libraries/Trill/Trill.cpp: use of undeclared identifier 'i2C_file'; did you mean 'i2cFile'? column: 33, line: 92 libraries/Trill/Trill.cpp:92:33: error: use of undeclared identifier 'i2C_file'; did you mean 'i2cFile'?
    if(int writtenValue = (::write(i2C_file, buf, bytesToWrite)) != bytesToWrite)
    i2cFile
    /root/Bela/include/I2c.h:27:6: note: 'i2cFile' declared here
    int i2cFile = 0;
    and 12 more errors similar to this on other lines. they all refer to "i2c_file".
    (i tried altering the Trill.cpp file in my downloaded "better-i2c-rebased" folder on my pc accordingly, rezip it and update the board with the altered branch, but that didn't work, it even showed the exact same errors. probably not at all the way to do this but at least i wanted to give that a try before i did another post)
    4 days later
    Thanks! the libpd project is building again with no errors. With heavy there still seem to be some issues: it doesnt want to accept the expression object from pd anymore; (in the master branch that compiled with no problems); root@bela:~# python2.7 ~/hvcc/hvcc.py ~/Bela/projects/MergedProjects/_main.pd -o /tmp/hvtmp -n bela -g c
    1) Error pd2hv: BaseMath in "_main.pd/BaseMath" @ (x:-515, y:498): Don't know how to parse object "expr". Is it an object supported by Heavy? Is it an abstrac tion? Have the search paths been correctly configured?
    2) Error pd2hv: BaseMath in "_main.pd/BaseMath" @ (x:-515, y:498): There was a n error while connecting two objects. Have all objects been correctly instantiat ed? Have all inlets and outlets been declared?
    3) Error pd2hv: [comment text] in "_main.pd/BaseMath" @ (x:0, y:0): Connection made to non-existent inlet at [comment {u'text': 'null object placeholder (expr )'}]:0.
    also when i try to compile the project with the expression object removed, the compiler still quits with 'segmentation fault': (everything seems to run smooth untill compiling the render.cpp) echo 'Building render.cpp...'
    g++ -I/root/Bela/projects/Trill_HEAVY -I./include/legacy -I./include -I./build /pru/ -I./ -I/usr/xenomai/include/cobalt -I/usr/xenomai/include -march=armv7-a - mfpu=vfp3 -D_GNU_SOURCE -D_REENTRANT -fasynchronous-unwind-tables -D__COBALT__ - D__COBALT_WRAP__ -DXENOMAI_SKIN_posix -DXENOMAI_MAJOR=3 -O3 -march=armv7-a -mtun e=cortex-a8 -mfloat-abi=hard -mfpu=neon -ftree-vectorize -ffast-math -DNDEBUG -D BELA_USE_RTDM -I/root/Bela/resources/stretch/include -save-temps=obj -std=c++11 -Wall -c -fmessage-length=0 -U_FORTIFY_SOURCE -MMD -MP -MF"/root/Bela/projects/T rill_HEAVY/build/render.d" -o "/root/Bela/projects/Trill_HEAVY/build/render.o" " /root/Bela/projects/Trill_HEAVY/render.cpp"
    /root/Bela/projects/Trill_HEAVY/render.cpp: In function 'void sendHook(HeavyCont extInterface*, const char*, uint32_t, const HvMessage*)':
    /root/Bela/projects/Trill_HEAVY/render.cpp:410:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writeNoteOn(channel, pitch, velocity);
    /root/Bela/projects/Trill_HEAVY/render.cpp:420:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writeControlChange(channel, controller, va lue);
    /root/Bela/projects/Trill_HEAVY/render.cpp:428:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writeProgramChange(channel, program);
    /root/Bela/projects/Trill_HEAVY/render.cpp:437:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writePitchBend(channel, value);
    /root/Bela/projects/Trill_HEAVY/render.cpp:446:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writeChannelPressure(channel, pressure);
    /root/Bela/projects/Trill_HEAVY/render.cpp:456:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writePolyphonicKeyPressure(channel, pitch, pressure);
    /root/Bela/projects/Trill_HEAVY/render.cpp:464:9: warning: comparison between si gned and unsigned integer expressions [-Wsign-compare]
    port < midi.size() && midi[port]->writeOutput(byte);
    /root/Bela/projects/Trill_HEAVY/render.cpp: In function 'bool setup(BelaContext* , void*)':
    /root/Bela/projects/Trill_HEAVY/render.cpp:487:28: warning: comparison between s igned and unsigned integer expressions [-Wsign-compare]
    for(unsigned int n = 0; n < touchSensor.numSensors(); ++n)
    ``echo ' ...done'
    ...done
    echo ' '
    ./resources/tools/detectlibraries.sh --project Trill_HEAVY
    Extracting dependencies of library Trill
    make -f Makefile.linkbela --no-print-directory /root/Bela/projects/Trill_HEAVY/T rill_HEAVY
    echo 'Linking...'
    Linking...
    g++ -Llib/ -fno-pie -no-pie -pthread -o "/root/Bela/projects/Trill_HEAVY/Tri ll_HEAVY" build/core/FormatConvert.o build/core/OscillatorBank_routines.o build/ core/math_runfast.o build/core/ringbuffer.o build/core/Gpio.o build/core/I2c_Cod ec.o build/core/BelaContextFifo.o build/core/RTAudio.o build/core/PruBinary.o bu ild/core/RTAudioCommandLine.o build/core/AuxTaskNonRT.o build/core/JSONValue.o b uild/core/board_detect.o build/core/WSServer.o build/core/AuxiliaryTasks.o build /core/PRU.o build/core/DataFifo.o build/core/AuxTaskRT.o build/core/IirFilter.o build/core/GPIOcontrol.o build/core/Spi_Codec.o build/core/I2cRt.o build/core/I2 c.o build/core/BelaContextSplitter.o build/core/DigitalChannelManager.o build/co re/JSON.o ./build/core/default_main.o /root/Bela/projects/Trill_HEAVY/build/Hv ControlSlice.o /root/Bela/projects/Trill_HEAVY/build/HvControlVar.o /root/Bela/p rojects/Trill_HEAVY/build/HvLightPipe.o /root/Bela/projects/Trill_HEAVY/build/Hv Table.o /root/Bela/projects/Trill_HEAVY/build/HvMessageQueue.o /root/Bela/projec ts/Trill_HEAVY/build/HvControlPack.o /root/Bela/projects/Trill_HEAVY/build/HvCon trolCast.o /root/Bela/projects/Trill_HEAVY/build/HvControlSystem.o /root/Bela/pr ojects/Trill_HEAVY/build/HvMessage.o /root/Bela/projects/Trill_HEAVY/build/HvUti ls.o /root/Bela/projects/Trill_HEAVY/build/HvControlBinop.o /root/Bela/projects/ Trill_HEAVY/build/HvControlDelay.o /root/Bela/projects/Trill_HEAVY/build/HvContr olPrint.o /root/Bela/projects/Trill_HEAVY/build/HvMessagePool.o /root/Bela/proje cts/Trill_HEAVY/build/HvHeavy.o /root/Bela/projects/Trill_HEAVY/build/HeavyConte xt.o /root/Bela/projects/Trill_HEAVY/build/Heavy_bela.o /root/Bela/projects/Tril l_HEAVY/build/render.o libraries/Midi/build/Midi.o libraries/Midi/build/Midi_c.o libraries/Scope/build/Scope.o libraries/Trill/build/Trill.o -lasound -lseasoc ks -lNE10 -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -l rt -lprussdrv -lstdc++ -Wl,--no-as-needed -L/usr/xenomai/lib -lcobalt -lmodechk -lpthread -lrt -lasound -lseasocks -lNE10 -lmathneon -lmathneon
    echo ' ...done'
    ...done
    echo "Running /root/Bela/projects/Trill_HEAVY/Trill_HEAVY "
    sync& cd /root/Bela/projects/Trill_HEAVY && /root/Bela/projects/Trill_HEAVY/Tril l_HEAVY
    Segmentation fault
    Makefile:564: recipe for target 'runonly' failed
    make: *** [runonly] Error 139
      maybe something goes wrong here?
      but I also noticed an error when updating the board; when updating through the IDE I see an error popping up. Don't even have the time to read or copy it well; but then it seems to update anyway. (the first project that I needed this branch for works fine, and also compiles in heavy with no problems whatsoever...)
      so I tried updating with the command line to see what happens. Quits with following error:
      Checking the board is up and running at root@192.168.6.2...done
      Board found at root@192.168.6.2
      Updating the Bela core code in root@192.168.6.2:/root/Bela
      All the changes to the CORE files in the remote folder /root/Bela will be LOST. The content of these files/folders will be lost:
      core include Makefile Makefile.libraries Makefile.linkbela examples Doxyfile scripts resources pru libraries
      Your projects stored in /root/Bela/projects should be safe (and surely you have already backed them up somewhere safe, haven't you?).
      Are you sure you want to continue? (y/N) y
      Updating Bela core files to remote folder /root/Bela
      Stopping Bela...done
      Updating files...Updated files: 0 ...done
      Scope
      Midi
      make: Entering directory '/root/Bela/resources/tools/bela-cape-btn'
      gcc bela-cape-btn.c -o bela-cape-btn
      make: Leaving directory '/root/Bela/resources/tools/bela-cape-btn'
      make: Entering directory '/root/Bela/resources/tools/board_detect'
      g++ "../../../core/GPIOcontrol.cpp" -c -I../../../include -o "build/GPIOcontrol.o" -std=c++11
      g++ "../../../core/Spi_Codec.cpp" -c -I../../../include -o "build/Spi_Codec.o" -std=c++11
      g++ "../../../core/I2c_Codec.cpp" -c -I../../../include -o "build/I2c_Codec.o" -std=c++11
      g++ "../../../core/board_detect.cpp" -c -I../../../include -o "build/board_detect.o" -std=c++11
      g++ "main.cpp" -c -I../../../include -o "build/main.o" -std=c++11
      g++ build/GPIOcontrol.o build/Spi_Codec.o build/I2c_Codec.o build/board_detect.o build/main.o -o "board_detect" -std=c++11
      build/I2c_Codec.o: In function
      I2c_Codec::I2c_Codec(int, int, bool)':
      I2c_Codec.cpp🙁.text+0x66): undefined reference to I2c::initI2C_RW(int, int, int)'
      I2c_Codec.cpp:(.text+0x7c): undefined reference to
      I2c::~I2c()'
      build/I2c_Codec.o: In function I2c_Codec::writeRegister(unsigned int, unsigned char)':
      I2c_Codec.cpp:(.text+0xfe6): undefined reference to
      I2c::writeRegisters(unsigned char, unsigned char, unsigned int)'
      build/I2c_Codec.o: In function I2c_Codec::~I2c_Codec()':
      I2c_Codec.cpp:(.text+0x113c): undefined reference to
      I2c::~I2c()'
      build/I2c_Codec.o: In function I2c::I2c()':
      I2c_Codec.cpp:(.text._ZN3I2cC2Ev[_ZN3I2cC5Ev]+0x38): undefined reference to
      vtable for I2c'
      build/I2c_Codec.o🙁.data.rel.ro+0x10): undefined reference to `typeinfo for I2c'
      Makefile:10: recipe for target 'board_detect' failed
      make: Leaving directory '/root/Bela/resources/tools/board_detect'
      make:
      ** [board_detect] Error 1
      An error occurred.`
        yannick build/I2c_Codec.o: In functionI2c_Codec::I2c_Codec(int, int, bool)':
        ok this should be fixed now. Is that the error you were getting when updating the board?
        yannick /root/Bela/projects/Trill_HEAVY/render.cpp: In function 'bool setup(BelaContext , void)':
        this is not a problem.
        yannick 1) Error pd2hv: BaseMath in "_main.pd/BaseMath" @ (x:-515, y:498): Don't know how to parse object "expr". Is it an object supported by Heavy? Is it an abstrac tion? Have the search paths been correctly configured?
        this has always been the case: heavy doesn't support expr (and it never did)
        yannick 3) Error pd2hv: [comment text] in "_main.pd/BaseMath" @ (x:0, y:0): Connection made to non-existent inlet at [comment {u'text': 'null object placeholder (expr )'}]:0.
        do you have an object called [comment ...] ? You should use proper comments, not non-existing objects of type comment.
        As to why it gives segmentation fault, I would need to have your Pd code and make it fail on my machine to be able to investigate what is going on. Also, what version of hvcc are you running? You should definitely use [this one]( https://github.com/giuliomoro/hvcc), which contains a critical fix.
          giuliomoro Thanks, yes that was the error i was getting while updating the board. it is fixed now. I dont have any objects named 'comment'; that error was due to the expr. object and heavy not accepting expr as an object. I was already using the hvcc from https://github.com/giuliomoro/hvcc , after the fix for the update_board it still gave me 'segmentation fault' but when i checked my custom render.cpp for heavy, i found a mistake in there; i got it out and everything now finally compiled as it should 🙂 thanks again for your help!
