Is it possible to run PD using all 8 analog inputs? If I set the number of Analog Channels to 8 in the settings, this necessarily changes the sample rate to 22050. Then when I try and launch a PD patch it says "The sample rate of analog and audio must match. Try running with --uniform-sample-rate".
I tried putting --uniform-sample-rate in the User Command Line Arguments, but that didn't work, it just gives the same error message.
So I suppose I need to force PD to launch at 22050k, but I'm not sure how to do that. Any thoughts?
