Ok cool I have sorted out rebuilding the kernel module, thank you for sending that over. However, when I run the particular project, it begins writing the file to usb and then throws the following error:
Bus error
make: *** [runide] Error 135
Makefile:581: recipe for target 'runide' failed
Bela stopped
Bela has disconnected. Any changes you make will not be saved. Check your USB connection and reboot Bela.
I've never had this error before as the project has always run fine. I also find that if I try running other projects such as an example Bela project it will run and then I get the following:
Then the board shuts down. Just to note that this error appears when using a normal bela. The other thread is for errors on my Bela CTAG Beast.
