Create project from zip archive shepard-risset shepard-risset.zip...
root@bela ~/Bela# journalctl -u bela_ide
-- Logs begin at Thu 2016-11-03 17:16:43 UTC, end at Sat 2020-04-25 02:48:19 UTC. --
Nov 03 17:16:57 bela systemd[1]: Started Bela IDE Launcher.
Nov 03 17:17:07 bela node[467]: starting IDE from /root/Bela/
Nov 03 17:17:08 bela node[467]: setting pwd timeout
Nov 03 17:17:08 bela node[467]: listening on port 80
Nov 03 17:17:09 bela node[467]: setting pwd timeout
Nov 03 17:17:10 bela node[467]: running on BelaMini
Apr 25 01:08:48 bela node[467]: time set to: Sat Apr 25 01:08:48 UTC 2020
Apr 25 01:08:49 bela node[467]: make '--no-print-directory' '-C' '/root/Bela/' 'syntax' 'PROJECT=basic' 'CL=-p16 -C8 -B16 -H-6 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0'
Apr 25 01:09:11 bela node[467]: make '--no-print-directory' '-C' '/root/Bela/' 'syntax' 'PROJECT=basic' 'CL=-p16 -C8 -B16 -H-6 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0'
Apr 25 01:09:16 bela node[467]: bad process-event { event: 'checkSyntax',
Apr 25 01:09:16 bela node[467]: currentProject: '',
Apr 25 01:09:16 bela node[467]: newFile: 'shepard-risset.zip' }
Apr 25 01:09:24 bela node[467]: make '--no-print-directory' '-C' '/root/Bela/' 'syntax' 'PROJECT=exampleTempProject' 'CL=-p16 -C8 -B16 -H-6 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0'
Apr 25 01:09:28 bela node[467]: make '--no-print-directory' '-C' '/root/Bela/' 'all' 'PROJECT=exampleTempProject' 'CL=-p16 -C8 -B16 -H-6 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0'
Apr 25 01:09:32 bela node[467]: make '--no-print-directory' '-C' '/root/Bela/' 'runide' 'PROJECT=exampleTempProject' 'CL=-p16 -C8 -B16 -H-6 -N1 -G1 -M0 -D0 -A0 --pga-gain-left=10 --pga-gain-right=10 -X0'
Apr 25 01:09:57 bela node[467]: Strip off the top-level folder: /tmp/shepard-risset_gQCEof/shepard-rissetshepard-risset/
Apr 25 01:09:57 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_gQCEof/shepard-rissetshepard-risset/'
Apr 25 01:09:57 bela node[467]: UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_gQCEof/shepard-rissetshepard-risset/'
Apr 25 01:09:57 bela node[467]: at emitWarning (internal/process/promises.js:65:17)
Apr 25 01:09:57 bela node[467]: at emitPendingUnhandledRejections (internal/process/promises.js:109:11)
Apr 25 01:09:57 bela node[467]: at runMicrotasksCallback (internal/process/next_tick.js:125:9)
Apr 25 01:09:57 bela node[467]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
Apr 25 01:09:57 bela node[467]: at process._tickCallback (internal/process/next_tick.js:181:9)
Apr 25 01:09:57 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 1)
Apr 25 01:09:57 bela node[467]: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_gQCEof/shepard-rissetshepard-risset/'
Apr 25 01:09:57 bela node[467]: (node:467) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Apr 25 01:09:57 bela node[467]: DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
Apr 25 01:09:57 bela node[467]: at emitWarning (internal/process/promises.js:92:15)
Apr 25 01:14:40 bela node[467]: Strip off the top-level folder: /tmp/shepard-risset_SUYb7n/shepard-rissetshepard-risset/
Apr 25 01:14:40 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_SUYb7n/shepard-rissetshepard-risset/'
Apr 25 01:14:40 bela node[467]: UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_SUYb7n/shepard-rissetshepard-risset/'
Apr 25 01:14:40 bela node[467]: at emitWarning (internal/process/promises.js:65:17)
Apr 25 01:14:40 bela node[467]: at emitPendingUnhandledRejections (internal/process/promises.js:109:11)
Apr 25 01:14:40 bela node[467]: at runMicrotasksCallback (internal/process/next_tick.js:125:9)
Apr 25 01:14:40 bela node[467]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
Apr 25 01:14:40 bela node[467]: at process._tickCallback (internal/process/next_tick.js:181:9)
Apr 25 01:14:40 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 2)
Apr 25 01:14:40 bela node[467]: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_SUYb7n/shepard-rissetshepard-risset/'
Apr 25 02:48:16 bela node[467]: Strip off the top-level folder: /tmp/shepard-risset_2MrE8l/shepard-rissetshepard-risset/
Apr 25 02:48:16 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_2MrE8l/shepard-rissetshepard-risset/'
Apr 25 02:48:16 bela node[467]: UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_2MrE8l/shepard-rissetshepard-risset/'
Apr 25 02:48:16 bela node[467]: at emitWarning (internal/process/promises.js:65:17)
Apr 25 02:48:16 bela node[467]: at emitPendingUnhandledRejections (internal/process/promises.js:109:11)
Apr 25 02:48:16 bela node[467]: at runMicrotasksCallback (internal/process/next_tick.js:125:9)
Apr 25 02:48:16 bela node[467]: at _combinedTickCallback (internal/process/next_tick.js:132:7)
Apr 25 02:48:16 bela node[467]: at process._tickCallback (internal/process/next_tick.js:181:9)
Apr 25 02:48:16 bela node[467]: (node:467) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). (rejection id: 3)
Apr 25 02:48:16 bela node[467]: Error: ENOENT: no such file or directory, lstat '/tmp/shepard-risset_2MrE8l/shepard-rissetshepard-risset/'
Apr 25 02:48:19 bela node[467]: setting pwd timeout
Apr 25 02:48:19 bela node[467]: -- Logs begin at Thu 2016-11-03 17:16:43 UTC, end at Sat 2020-04-25 02:48:19 UTC. --
Apr 25 02:48:19 bela node[467]: Nov 03 17:16:57 bela systemd[1]: Started Bela IDE Launcher.
Apr 25 02:48:19 bela node[467]: Nov 03 17:17:07 bela node[467]: starting IDE from /root/Bela/
Apr 25 02:48:19 bela node[467]: Nov 03 17:17:08 bela node[467]: setting pwd timeout
Apr 25 02:48:19 bela node[467]: Nov 03 17:17:08 bela node[467]: listening on port 80
Apr 25 02:48:19 bela node[467]: Nov 03 17:17:09 bela node[467]: setting pwd timeout
Apr 25 02:48:19 bela node[467]: Nov 03 17:17:10 bela node[467]: running on BelaMini
Apr 25 02:48:19 bela node[467]: Apr 25 01:08:48 bela node[467]: time set to: Sat Apr 25 01:08:48 UTC 2020
root@bela ~/Bela# grep v0 /etc/motd
Bela image, v0.3.7d, 11 March 2020
