This thread's kinda dead, but I've spent a good amount of time on this subject myself so I'll chime in 😁
I've found that cross-compiling some pieces of my program with the Linaro toolchain (as discussed in this wiki page) works well for me. I have a script that needs to run on boot before initing the Bela environment, so if there are changes to it, I cross-compile and copy it to the board as part of my build script. The build script I use is just a shell script that automates input to several of the Bela build scripts so that I can run a bunch of build tasks with a keyboard shortcut from vscode.
thetechnobear note... i do understand that perhaps Bela's primary target was 'ease of use' for non-engineers.
but on the other hand, I suspect the nature of Bela means there are quite a few software engineers using it, as its a great hardware platform... and for us, we might have slightly more 'complex' needs for projects, esp. when integrating with our other software.
This is pretty spot on imo - on this forum especially, I tend to see the "engineer" and "non-engineer" interests diverging more and more. However, I don't imagine that it's in the Bela dev's best interest to devote a lot of time to supporting a relatively small high-end community, so I think the more community-driven work that can be done in that field, the better.
    ebai101 However, I don't imagine that it's in the Bela dev's best interest to devote a lot of time to supporting a relatively small high-end community,
    yeah, I totally agree.... I think 'hooks' and a recognition is all we could wish for.
    (e.g. the fact the make field on the IDE is only 20 chars wide... thats not even enough for an include path 😉 )
    BUT... I do agree, perhaps the IDE is not really the right tool for my purpose...
    cross-compiling - yeah, this is something Ive been seriously considered a few time, and recently was thinking about it again - i don't need an ide, but it would I could use my favourite code editor.
    I also like the idea of not having bela running 'extra code' (ide)
    of course bela is open source, so I could be tackling these issues myself and contributing back, but unfortunately it seems whenever I bring out bela... its due to wanting to get something done, so I never invest the time I really should do to make it better (for me and others)
    hmm... will see if I can invest some time in this....
    very tempted with the cross-compiler route (I'm reasonably familiar with this due to axoloti),
    if i do it, I could document the process for others.
    one thing id like to also consider is if/how the new UI (and old 'scope') aspects could be used in this environment...
    perhaps node could run on the local machine?
    anyway, thanks @ebai101 , nice to hear others thoughts and ideas on this topic.
      k, Im building up the cross compile environment, trying to use clang
      seems to be find, except im getting a link error
       "/usr/local/bin/arm-linux-gnueabihf-ld" --sysroot=/Users/kodiak/Projects/bela_client/sysroot -EL -X --eh-frame-hdr -m armelf_linux_eabi -dynamic-linker /lib/ld-linux-armhf.so.3 -o render /Users/kodiak/Projects/bela_client/sysroot/usr/lib/arm-linux-gnueabihf/crt1.o /Users/kodiak/Projects/bela_client/sysroot/usr/lib/arm-linux-gnueabihf/crti.o /Users/kodiak/Projects/bela_client/sysroot/usr/lib/gcc/arm-linux-gnueabihf/6.3.0/crtbegin.o /Users/kodiak/Projects/bela_client/sysroot/usr/lib/gcc/arm-linux-gnueabihf/6.3.0/crtfastmath.o -L/Users/kodiak/Projects/bela_client/sysroot/usr/lib/gcc/arm-linux-gnueabihf/6.3.0 -L/Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib -L/Users/kodiak/Projects/bela_client/sysroot/usr/local/lib -L/Users/kodiak/Projects/bela_client/sysroot/usr/xenomai/lib -L/Users/kodiak/Projects/bela_client/sysroot/lib/arm-linux-gnueabihf -L/Users/kodiak/Projects/bela_client/sysroot/lib/../lib -L/Users/kodiak/Projects/bela_client/sysroot/usr/lib/arm-linux-gnueabihf -L/Users/kodiak/Projects/bela_client/sysroot/usr/lib/../lib -L/Users/kodiak/Projects/bela_client/sysroot/lib -L/Users/kodiak/Projects/bela_client/sysroot/usr/lib --no-as-needed -lcobalt -lmodechk -lpthread -lrt -lprussdrv -lstdc++ -lasound -lseasocks -lNE10 -lmathneon -ldl -lbela -lbelaextra /var/folders/82/hvyfd1n518vfcys507wjrgtm0000gn/T/render-8a46bb.o -lstdc++ -lm -lgcc_s -lgcc -lc -lgcc_s -lgcc /Users/kodiak/Projects/bela_client/sysroot/usr/lib/gcc/arm-linux-gnueabihf/6.3.0/crtend.o /Users/kodiak/Projects/bela_client/sysroot/usr/lib/arm-linux-gnueabihf/crtn.o
      /usr/local/bin/arm-linux-gnueabihf-ld: /Users/kodiak/Projects/bela_client/sysroot/usr/lib/arm-linux-gnueabihf/crt1.o: in function `_start':
      (.text+0x28): undefined reference to `main'
      /usr/local/bin/arm-linux-gnueabihf-ld: /Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib/libbela.so: undefined reference to `BelaContextSplitter::setup(unsigned int, unsigned int, BelaContext const*)'
      /usr/local/bin/arm-linux-gnueabihf-ld: /Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib/libbela.so: undefined reference to `BelaContextSplitter::cleanup()'
      /usr/local/bin/arm-linux-gnueabihf-ld: /Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib/libbela.so: undefined reference to `BelaContextFifo::push(BelaContextFifo::fifo_id_t, BelaContext const*)'
      /usr/local/bin/arm-linux-gnueabihf-ld: /Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib/libbela.so: undefined reference to `DataFifo::DataFifo()'
      as you can see I include -lbela -lbelaextra , and -L/Users/kodiak/Projects/bela_client/sysroot/root/Bela/lib contains the libs (a/so)
      btw: really like belaconfig - thats really cool 🙂
      is libbela/libbelaextra missing something - or have i got something missing?
      you have to add the objects build/core/DataFifo.o build/core/BelaContextFifo.o build/core/BelaContextSplitter.o to whatever settings you are using to create libbela.so. If you created that on Bela itself, make sure you have at least this commit on it
      commit 63d5ccf053843ccc7030bbda2f8186dc96fed267
      Author: Giulio Moro <giuliomoro@yahoo.it>
      Date:   Sun Jan 26 20:45:05 2020 +0000
          core: added more object files to libbela
      actually just figured it out... I just needed to rebuild lib
      make lib
      the other thing i needed to do, was to copy over default_main.o (or I guess i can compile that locally)
      EDIT: indeed now I copy default_main.cpp, and compile that on the host.
      anyway cross compiling is now working nice on macOS
      im going to do some tidying up, and ensure its all running on Linux nicely, then will share what Ive done 🙂
      basically, the goal is a quick to setup environment for anyone that wants to cross compile and use the the command line on mac or linux.
      theres not really a lot to it, but I wanted it to be quick to install on new machines, as I use a few different macs and linux boxes here 😉
      ok, Ive got the basics working on both linux and macos
      https://github.com/TheTechnobear/bela_client
      basic goal is cross-compiling client on mac/linux thats easy to install and use, currently im only interested in C++ support - so not SC/PD , but I guess those are no more than copying files and launching.
      currently, it provides:
      - a quick/easy install
      - belaCompile, belaRun, belaCompileRun ... to compile/run simple cpp code (i.e. single render.cpp type things)
      - belaExec, belaCopy functions to copy/execute on bela
      - sets up normal Bela/scripts , so you can just type ide.sh stop
      testing:
      the mac version ive done a proper clean install on, the linux was a bit 'made up as i went along... as I had issues with the available clang/llvm versions on my distro... but i pretty confident its accurate (and certainly past installation its fine)
      to do:
      - add default options when running (as per IDE i guess)
      - cmake template
      cmake is the main thing, really things like belaCompile were just created so that I was clear on what compile option and executables I need to get things to compile - should be relatively easily for me to translate that to cmake (which Im pretty familiar with).
      once thats done, I'll start using 'in anger' so no doubt might add a few more things, that make it easier to do the edit,test,run workflow....
      I also want to think about
      - where i put the compiled 'projects' on bela
      - tailoring 'startup', so that i can run these projects.. or perhaps make 'compatible' with current startup routing (which starts via make)
        thetechnobear , but I guess those are no more than copying files and launching.
        Actually Pd projects are all built (linked-only, because all the .o files will already be ready), though - unless the provide a custom C++ file - the binaries are all the same. Either way, Bela/scripts/build_project.sh can take care of those.
        ebai101 However, I don't imagine that it's in the Bela dev's best interest to devote a lot of time to supporting a relatively small high-end community, so I think the more community-driven work that can be done in that field, the better.
        yup. The IDE is the pain-free way to getting started. More advanced users can use the scripts, make or any solution they come up with. The existence of the pre-built library is a way to encourage integration in different workflows (see, e.g.: here).
        @ebai101 do you want to add a wiki entry for your VS workflow?
        FWIW: I use vim on the board and make from the command line most of the times.
        thetechnobear (e.g. the fact the make field on the IDE is only 20 chars wide... thats not even enough for an include path 😉 )
        I know right, I just reopened this, which got closed for unclear reasons https://github.com/BelaPlatform/Bela/issues/362
        As always, there is much more to do than there is time available, so ... we do what we can and we very much welcome community contributions 🙂
          @thetechnobear looks awesome! I'll try it out when I can.
          giuliomoro @ebai101 do you want to add a wiki entry for your VS workflow?
          For sure - I wrote a post about it a while ago which I could edit into a page. I'd love to try and integrate with this new xc instead, though, since it looks like it'll make the setup easier.
            giuliomoro a docker image
            Funny you mention that, I actually tried that a little while ago - I imported a Bela image into docker and compiled some examples in a container. Everything seemed to run fine when I copied them to the board, with no other config required. I didn't have the time then to write something to interface it smoothly with the board, so I left it be.
            A toolchain like dockcross might be perfect - would just need to make the container filesystem line up with the Bela. It could probably be extended from a dockcross image actually; their linux-armv7a image is set up for the stock BBB.
              ebai101 A toolchain like dockcross might be perfect - would just need to make the container filesystem line up with the Bela. It could probably be extended from a dockcross image actually; their linux-armv7a image is set up for the stock BBB
              sounds promising, I may have a look if time allows
              sent you a PR for #624 to build a 'full' library of bela objects.
              also Ive switch xcBela over to use update_board and xcCompile now uses this new lib.
