david I am sorry but I do not understand 'to update to the latest master branch'
sorry here's a guide https://learn.bela.io/using-bela/bela-techniques/updating-bela/#updating-with-the-ide
david The s is for 'set' in the message box.
but it won't change anything in the object it is connected to, I think? Also now that I see your patch again and I see it's a [+~ 0.2] (and not a [+ 0.2] as I thought) so it doesn't need to receive any message for the patch to work.
Anyhow, the problem seems to be that for some reason your CTAG capes are not detected when the Bela cape is connected. You can run this in the console at the bottom of the IDE to force it being recognised:
echo BOARD=CtagBeastBela > /run/bela/belaconfig
(needs to be redone after each reboot).
Does it work after this ? Run it again with --verbose and post the result in case it doesn't, please.
