flex009 I also want to know type of mic I needed to hock up at audio in port? Can I use MEMS based microphone like ICS-40730
that should be fine. You can get power from the 3.3V pin.
flex009 Is there any example code exists?
What programming language are you planning on using? There is no C++ example code for audio recording, but if you use PureData, you can use [writesf~] to record to disk easily.
flex009 ,could you please help? Thanks
No need to tag me 7 minutes after posting your first question.
