Hi all,
I’m currently having a slight issue of writing wav files to usb stick that is connected to Bela. I’ve tried a couple of different versions of the specified path in my code using ./ for current working directory etc but not having any success. Here is the absolute path that I originally used before trying different versions:
const char* path = "/root/Bela/projects/audioRecorderV07/usb/audioCh.wav”;
I have successfully mounted the usb (which is formatted as FAT32 with an MBR partition map) to Bela. I have an example file on the usb and its there when checking through terminal/ssh, so I know that there is access but just no WAV files are being written to the usb after the project has run and stopped. Important to note that all the rest of the code is working with regards to recording and writing to wav files etc but just can't get this part to function.
Thank you in advance for your help.
